Twisted axles splines 10 bolt
Old 05-30-2015 | 01:14 PM
GMCtrk's Avatar
Default Twisted axles splines 10 bolt
No symptoms from the rear end, however, was pulling the rear axles today and found twisted splines on my driver's side Moser axle. Passenger side was normal. I'm leaning towards exceeding the limit of the 10 bolt versus a bad axle from Moser, but I know others have gone faster.
Old 05-30-2015 | 02:34 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
not the first one I've seen twisted skeet was running moser axles in his old truck truck which ran low 11s high 10s
Old 05-30-2015 | 03:56 PM
oakley6575's Avatar
That sucks man! Are you going to ask Moser about it?
Old 05-30-2015 | 04:05 PM
GMCtrk's Avatar
Wasn't planning on it, they'll probably just come back at me saying a 30 spline axle wasn't meant to handle that stress. And I couldn't argue against that.
Now, upon searching a bit, I have found a lot of people with twisted Moser axles. So I'm not sure if I should try again with my stock axles or start looking for a 14 bolt out of an SS.
Old 06-01-2015 | 01:21 AM
Suburbazine's Avatar
14 bolt is always better if you don't mind the slight extra weight.
I'm going 14 bolt on mine for sure and I'm not pushing as much power as you are.
Old 06-01-2015 | 02:54 AM
Jeebalow's Avatar
What is the weight difference? Any idea?
Old 06-01-2015 | 05:23 AM
1bad2k's Avatar
About 75-80 lbs
Old 06-01-2015 | 07:46 AM
George C....'s Avatar
Formerly ScreamingL
honestly, look up that company in texas that makes a bolt in 9", i have the 14 bolt and if there was a 9" available when i did the swap i would of went 9" in heartbeat
Old 06-01-2015 | 02:38 PM
1FastBrick's Avatar
Custm2500's Rude Friend
As much as I like the 14 bolt design for what it is, The one in the SS is a hybrid. It uses a 10 bolt axle bearing with a 33 spline. At some point, even those are prone to twist. The axle flange is also subject to failure as well as a few guys have broke them on slicks.
Like George C says go 9 inch and don't look back. For all types of racing, the basic design of a 9 inch is far superior. There are also plenty of upgrades the faster you go.
The 9 design has various advantages over the 14 bolt:
A larger cross section at the axle bearing.
Multiple spline options for different levels of power.
Multiple custom axle options.
Multiple spool, locker type options
Larger selection of gear ratios.
Various Brake options.
No C-clips to worry about.
Much easier to brace up.
Gear set ups can be done on the third member itself while it's on a bench.
Old 06-01-2015 | 03:05 PM
GMCtrk's Avatar
What's the cost of one of those Ford 9" rear ends. Isn't it going to end up being over 3k?
I can get a junkyard 14 bolt with evertything on it and 3.73 or 4.10 gears for $1000-1200. I can sell my current rear end being worth at least $500 (trutrac and AAM 4.10 gears). And I can swap over my rear brakes or just run the 14 bolt drums, both of which would clear 15s.
At this point, it's all about cost to benefit ratio because I'm tired of dumping money into an old truck which is only worth about $4000 based on age and mileage. I just want a 10 second slip and be able to drive home.
Just out of curiosity, would the twisted axle be a reason I could never leave the line without spin after my first ever 1/4 mile pass on the drag radials? That first run it dead hooked 1.63 60' and since that point it could never hook up cleanly.
Quick Reply: Twisted axles splines 10 bolt
