Compatability questions
Old 11-16-2013 | 02:20 AM
gamble686's Avatar
Default Compatability questions
I am doing a cam swap on my 2000 4.8 and want to make sure I don't miss any of the little insurance stuff for down the road. I thought I knew some things I wanted until I started buying stuff now I am questioning myself a lot
So lets start with the easy stuff.
Ls2 timing chain this should fit fine right? I don't want to buy sprockets if its not 100% needed
Head gaskets.... Some sites say that 12498544 only fits 02 and up I thought they should all be the same?
Is the timing chain damper seal necessary?
Oil pickup tube oring? Red or blue or not necessary?
I know I'm forgetting something but I will add later.
Old 11-16-2013 | 02:37 AM
gamble686's Avatar
Well I guess I answered my own question they switched from graphite to MLS that year but both fit. So I will be going MLS. I am getting conflicting answers on the timing chain.
Old 11-16-2013 | 11:21 AM
jmgak47's Avatar
Yes the LS2 timing chain is a direct swap and your factory sprockets are just fine, no need to replace them.
The 99-01 heads had a recessed notch and originally came with graphite gaskets. The part number is 12457116
Or you can use a Victor 54441 head gasket which is the newer style MLS style but will retro fit the 99-01 heads.
You mean the front cover gasket or the crank seal? Both should be replaced.
Old 11-16-2013 | 11:42 AM
black01_WS6's Avatar
Timing chain is direct swap.
Are you getting the heads worked on? Cheap hp for some minor work
AKlowriderZ71's Avatar
11 Second Hall Moniter
Since your engine is from a 2000, you will need to check your heads for the "notch". If you have the notch, you will not be able to run MLS gaskets. Here's a pic for reference.
Old 11-16-2013 | 12:09 PM
Txblue's Avatar
I thought the oil pump has to come off to replace the timing chain? If so YES replace the o-ring. I put a red one in mine.
Old 11-16-2013 | 12:55 PM
jmgak47's Avatar
Your correct, I don't know what I was thinking.
Old 11-16-2013 | 01:21 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You mean Some of the heads had the notch. Not all.
Old 11-16-2013 | 01:23 PM
Correct. Some had the notch, and some did not. The OP needs to check for the notch if he wants to use the better MLS gaskets.
Old 11-16-2013 | 01:34 PM
jmgak47's Avatar
Well, ya learn something new everyday.
