Dual 14" Aluminum fan shroud. 1/8 material.
Former Vendor
I built 2 of these units, one was made from .093 an the other is .125.
3003 matrial fully tig welded.
After installing the .093 to see if it was thick enough, yep plenty thick.
The fan bolt pattern is cut for Spal 14" style fans. The 1/8 is plenty thick if you need a differnent parttern to match to your fans. The shroud fits perfectly in the stock location with NO modifaction to the core support, and no extra fab work to install. It even plugs into the stock mid, support just like the oem unit does.
$200.00 I will pay for the shipping. fans not included.
Ricky
Ricky
Former Vendor
Originally Posted by ranwalk
Looks good. What size radiator is it for? 28 inch core or 24 inch. Could you make one for a 34 inch radiator and hold 2 16 inch fans?
Ricky
murderedSS
27
10-12-2015 11:13 AM
Alvin@PCMofNC
09-03-2015 06:38 AM
