Does this engine cover bolt right on?
Old 12-21-2009 | 10:32 PM
DriftR's Avatar
Default Does this engine cover bolt right on?
Cause if it does... I want one for my little 4.8L!
(sorry the pic is so big?) SnakeOiler, hope you don't mind me using it. If nobody knows I'll try a P.M.
Old 12-21-2009 | 11:07 PM
StrokerAce03's Avatar
Yes it does.
Old 12-21-2009 | 11:19 PM
Bumpers's Avatar
Just look at the holes on your valve covers and make sure they are threaded if so good to go... I've heard some of them aren't threaded
Old 12-21-2009 | 11:24 PM
2005 Silverado's Avatar
SPAM HUNTER
There are some studs that go on the valve covers, then those have a ball'd end that the covers snap onto, then the middle one bolts on.
Old 12-22-2009 | 06:44 AM
SnakeOiler's Avatar
That must be how the new ones fasten up, because all three covers (above) bolt on.
DriftR, they'll fit your 4.8 and I don't mind you showing off my engine (even if it is the old alternator )
Are you wanting all three covers or just the middle one? I'm using:
15006417
15006418
12579166 - center cover
There are lots of different part numbers for the side covers, but these are the ones I am using.
Old 12-22-2009 | 11:07 PM
DriftR's Avatar
Thanks for the info all... I'd like to get all three, what did they come off of, anything with a 6L?
If I can't pull it from the boneyard I'll use the part numbers. What will I be looking to pay for them new?
Old 12-22-2009 | 11:51 PM
SnakeOiler's Avatar
Denali's, Escalade's, SS trucks. perhaps more. All of the 6.0L engines may have had these, I'm not positive.
gmpartsdirect has GM cost at:
15006417 - not listed
15006418 $35
12579166 $30
Old 12-23-2009 | 12:28 AM
RandomHero's Avatar
I know for a fact that they won't bolt up to a 99 silverado. I have the exact same covers and the side covers won't bolt up to the valve covers like they're supposed to. On the trucks that have that engine cover, there are threads on the valve covers that they bolt to. Mine has none. That's not to say you can't make it work, I just haven't found a way I'm comfortable with yet.
Old 12-23-2009 | 12:52 AM
DriftR's Avatar
Pulled this from another thread as well (lil different):
Pn# 12598332/center 12597908/lh 12574573/rh
Old 12-23-2009 | 11:52 AM
SnakeOiler's Avatar
Oh yeah, the VortecMax engines, forgot about those. Another 6.0L
Just a note: the center covers are cut like that for clearance of the drive by wire throttle - all of the DBW covers will be designed like that.
Here's an example of an SS center cover and an Escalade center cover: http://s2.photobucket.com/albums/y28...o/IMG_0254.jpg
Quick Reply: Does this engine cover bolt right on?
