FS: Misc front accessory parts
Old Oct 17, 2006 | 01:36 PM
thunder550's Avatar
High on diesel fumes
Default FS: Misc front accessory parts
All are from a 2005 LQ9 with approx 10K miles.
Water pump with stock t-stat $35
Alternator and p/s pump bracket (with idler pulley) $30
105 amp alternator $60
A/C compressor (unknown condition) and bracket/bolts/tensioner: $30
Pics available upon request.
Old Oct 17, 2006 | 03:08 PM
Mangled03gmc's Avatar
Baltimore Whore
Hey what will that water pump be shipped to baltimore md 21219, all the pumps are the same on the truck motors correct.. Thanks
Old Oct 17, 2006 | 07:19 PM
thunder550's Avatar
I think they are all the same, the inlet where the t-stat mounts is smaller in 03+, but it should match what you have already.
Add $12 for shipping to you. $47 shipped.
Old Oct 17, 2006 | 07:23 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Pics of the AC comp. How unknown is the condition?
Old Oct 17, 2006 | 07:26 PM
Baltimore Whore
Ok this will be going on a 05 lq4 so that should work then. Also the shaft or nothing on the pump is bent correct.. Thanks JOHN, also can yah send me pics to mangler0075@aol.com..
Old Oct 18, 2006 | 12:28 AM
thunder550's Avatar
Pics!!!
Mangled03gmc, the pulley on the w/p spins without binding, so the shaft is not bent.
1SlowHoe.....I took a vid of the compressor, the pulley spins freely since the clutch is disengaged but makes a little bit of a ringing sound, I can't figure out what it is. Spinning the compressor itself turns the rotors or whatever is inside. Also, when the engine was delivered to me there was coolant mixed with the oil in the compressor, I assume that can be cleaned out but I'm not sure about it. See pics below and video link.
Compressor video (quicktime, 9 megs)
Old Oct 18, 2006 | 08:55 AM
Baltimore Whore
Hey can ya pm me your paypal adress..
Thanks JOHN
Old Nov 15, 2006 | 08:10 PM
thunder550's Avatar
ttt....still have everything!
Old Nov 26, 2006 | 07:41 PM
thunder550's Avatar
ttt....
Old Nov 28, 2006 | 11:01 PM
thunder550's Avatar
ttt...
