Performance Suggestions,, FI Experts Inside Please
I am currently runing 12.5-12.6 range but I can't seem to break into the low 12's. I wondering if the 2.8" pulley is generating to much heat at the end of my runs. My IAT's jump to 150 at my 2-3 shift point.
Is this just the nature of the beast running the radix?
I was wondering how much a meth kit would help control this rise in IAT.
I am also planning on the 90mm TB modification.
Looking for suggestions that will help control temps and get me solidly and consistantly into the low 12's.
Thanks in advance for any input.
I doubt you will hit any better then a 12.35 with those additions. Unfortunately the little radix is out of steam, maybe consider the 122 upgrade, that should get you into the 11s. As you will see time and again with radix charged trucks they hit a brick wall at mid 12s, unfortunately they just cant flow the CFM to get you going any faster in our heavy trucks.
how much boost do you have now
no the 122 upgrade will spin not nearly as fast to get the same effect and therefore less heat
you will need a bigger pulley for the 122 cuz a 2.8 pulley would be too much for what you are wanting
ive always heard that about 8-10psi is about the limit for the gen3 stock bottom end
i think if i were you and dead set on a low 12 i would check this out...
https://www.performancetrucks.net/fo...=radix+nitrous
The limits of the stock bottom end aren't boost dependent - they are HP dependent. That being said, I don't know what the limits are.....
But...check out WildeRacing....he has a mid-low 11 STS truck on a stock bottom end, I think he is pushing close to 15 psi with a 6.0
