4L80E swap guys
4L80E swap guys
Few questions:
What wiring harness / PCM are you running? (Year, Model)
If it was not a harness for a 4L80E how did you do your connector?
1) Use a cut off 4L80E connector and tap in to the harness / pcm
2) Repin a new connector in to the harness / pcm
3) Other (please explain)
What did you use for programing in regards to comanding the 4L80E perameters?
I think that's all I have for questions right now. Thanks in advance.
Adkoonerstrator
Yep, there is a conversion harness to adapt the 4L60E harness. Speed Engineering sells it also. With the 4L80E you will also need a second VSS sensor which speed sells too, it comes with instructions on how to pin it into the PCM.
http://speed-eng.com/store/product_i...oducts_id=6625
Any of the popular tuning softwares can reflash a 80E file into your PCM. When you reflash the PCM you need to flash the ENTIRE Operating system from a 80E truck into it. Whatever software you use look for a file from a 6.0L/4L80E/2wd truck, that will be the best starting point for you.
What year PCM do you have now?
How do I change this text
lxcoupe
07-21-2015 02:12 AM
4l80, 4l80e, conversion, engineering, flash, harness, pcm, program, programing, reflash, reflashing, speartech, speed, swap, tune
