Garage sale! Engine parts
Old Nov 30, 2006 | 12:06 PM
thunder550's Avatar
High on diesel fumes
Default Garage sale! Engine parts
See below - when referencing the 6.0 (LQ4) motor parts, it's a 2005 with 20K miles. When referencing 5.3 (LM7) parts, it's a 2001 with 118K miles. (unless otherwise specified)
Water pump from a 2005, includes stock t-stat. 10K miles. $40 shipped SOLD!!!
Two stock oil pumps - one from my 5.3, working perfectly when engine removed. One from my 6.0, low oil pressure, not sure if it was oil pump or a different problem. $25 each or $45 for both shipped.SOLD!!!
Two stock timing sets - one from my 5.3, one from my 6.0 (same as LS2). Both are in good shape. Full timing sets. $25 for the 5.3 set, $60 for the 6.0 set, or $80 for both shipped.
Two sets of Stock lifters - one from my 5.3, one from the 6.0. Only have one set of lifter cups/trays - add $5 to your price if you want them. Includes bolts. $20 each or $35 for both shipped. 6.0 LIFTERS SOLD, 5.3'S STILL AVAILABLE!!!
Stock pushrods - 10K miles. Good condition. $15 shipped
Front, rear, and valley covers from the 5.3. Includes bolts. $50 shipped for all three. Make offer if you need an individual cover. SOLD!!!
Truck Oil pan. $30 shipped. Includes bolts. SOLD!!!
Oil pickup tube & windage tray from the 5.3. Includes bolts/nuts. $20 shipped for both. SOLD!!!
Crank pulley - stock truck pulley. Good shape. $30 shipped SOLD!!!
LQ4 rods and pistons - 20K miles, good condition. $50 shipped. SOLD!!!
317 heads - 20K miles. Good condition. Complete except for springs. $250 shipped SOLD!!!
5.3 iron block (bare) - great condition, 118K miles, you can still see the cross-hatching on cylinder walls. $75, will have to arrange for shipping and/or pickup cost. SOLD!!!
Alternator bracket w/ idler pulley - great condition $35 shipped SOLD!!!
05 stock alt. 105 amps, 10K miles. $35 shipped SOLD!!!
V8 1/2 ton engine mounts with engine-to-mount bolts $25 shipped SOLD!!!
Old Nov 30, 2006 | 12:27 PM
Scream's Avatar
MOOBIES Moderator
Won't the fornt/rear/valley covers work on a 6.0L block? If so, I'll take them for $40 shipped as long as they're in good shape.
Old Nov 30, 2006 | 12:30 PM
Ws6Luvr's Avatar
will that waterpump work on a 2000 5.3 motor? and will the 6.0 liter timing chain set work on a 2000 5.3 as well? thanks.
Old Nov 30, 2006 | 01:18 PM
thunder550's Avatar
Yes, I believe they are the same. I was just listing what they came off of. Sending you PM.
Old Nov 30, 2006 | 01:21 PM
thunder550's Avatar
The waterpump will work on the 2000 motor, the only difference is the thermostat hole is a little smaller on the 03+. If you ever need to replace the t-stat you'll have to buy one from an 03+.
The timing set will work as well. If you need the bolts for the cam gear I will include them.
Old Nov 30, 2006 | 01:50 PM
Scream's Avatar
MOOBIES Moderator
PP sent!
Old Nov 30, 2006 | 01:53 PM
thunder550's Avatar
PP sent!
Thanks, will ship tomorrow
Old Nov 30, 2006 | 01:58 PM
thunder550's Avatar
Edit - added a few things
Old Nov 30, 2006 | 02:22 PM
Scream's Avatar
MOOBIES Moderator
Hmmmmm, I probably need those lifter cups too, but I don't need the lifters. If you have trouble getting rid of the lifters, I'll take 'em off your hands.
Old Nov 30, 2006 | 02:23 PM
thunder550's Avatar
Cool, I'll let you know
