No More LQ9's
Ordered the 6.0L from Scoggin-Dickey today. Found out GM has discontinued manufacturing the LQ9's, even as crate motors. Had to settle for an LQ4.
![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
Originally Posted by GMC_DUDE
Ordered the 6.0L from Scoggin-Dickey today. Found out GM has discontinued manufacturing the LQ9's, even as crate motors. Had to settle for an LQ4. ![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
SHould have ordered an L92![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
![MAD](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_mad.gif)
Originally Posted by KevinF56
wouldnt you rather have an LQ4 for a radix because of the lower compression ratio?
not imo , the 112 cant produce enough boost on a 6.0 to where the compression ratio will hurt performance. if you have goals to go bigger than yes an lq4 would be a better choice.
