Small base circle cam question.
I was told by a sponser ...That I needed 7.45. I believe the 02 ls6 valve is .7 millimeters longer which comes to .275 inch difference, so I am not sure why I was told I would need 7.45's. I do know I have the 7.45 on my tool box and if they are wrong ...my install schedule is PHUCKED!!!
I have read old posts for over an hour and found people have used this cam with 7.4 , 7.425, and 7.45 pushrod lenths and they all claim it worked out fine.
How much difference could .25 make anyhow. Its not like I am running solid lifters???
You can use you stockers to get it going and order some 7.425 if you want, but I ran that cam with stock push rods in my motor for 10K+ miles.
Originally Posted by kbracing96
Valve stem contact won't change unless your running adjustable rockers, it the about of pre-load the lifter will see that will be different.
So much for a simple add on
Is the extra .025 gonna be to much preload you think. Looking at that amount on a dial caliper its pretty damn small. maybe I should just send em back now? I need a drink
Valve stem contact won't change unless your running adjustable rockers, it the amount of pre-load the lifter will see that will be different.
Geometry Lesson
All pushrod engines that pivot a rocker arm on a stud determine the location of the rocker-arm tip relative to the valve tip with pushrod length. The small-block Chevy, along with many other production engines, originally came equipped with stamped-steel rocker arms. These rockers used a very wide rocker tip with a very gentle radius that was extremely forgiving when it came to pushrod length. The pushrod length could be short or long and the broad rocker-arm tip would accommodate it.
let me know what you think.
And thanks for reponding. I think all of us are learning.
That is true on the small blocks and with adjustable rocker on these motors, but stock rockers are not adjustable, they tighten down against the saddle and there for the pivot point on the rocker can not change in relationship to the valve, so the contact point will be the same.
See where I'm coming from on this. The rocker will always be in the same location, no mater what push rod you install in the motor, a longer push rod just pushes the lifter piston further into the lifter.
