Doug Thorley Tri-Y Coated Headers THY-310Y-C
Old Jan 8, 2008 | 12:21 PM
DamnYankee's Avatar
formerly Moze (2/24/2012)
Default Doug Thorley Tri-Y Coated Headers THY-310Y-C
These are just over a year old - I bought them in September of '06 and had them on my Z71 (so yes they will fit 4wd) and took them off a couple of months ago when I put the truck back to stock. They're listed as fitting 1999-2001, TRUCK/SUBURBAN/TAHOE/YUKON, 4.8L-5.3L, 2/4WD, but again, these were on my 2003. SCIV also runs these if you want to get his input on them. I'm not sure if they'll fit the NNBS or not...? They're in excellent condition and come with the gaskets that were provided by Thorley. I used the gaskets and had no issues with leaking (even with a missing header bolt). These felt amazing on my extended cab Z71 but I need long tubes with my new setup. You won't find a better made header than the Thorley's. They use 14 gauge steel and 3/8" flanges (try to find better). Ask anyone who has them not only about the quality but about how they perform. These currently sell for $1,002 on Thorleys site (obviously overpriced) and $669 on Summit. I'm asking $475 shipped or $450 if picked up in person.
Actual photo:
Stock photo (or click here for a link):
The best way to get rid of your exhaust.
Thorley headers are designed to outflow your stock exhaust manifolds. These headers increase gas mileage and give your engine more horsepower across the entire rpm range. The Tri-Y configuration builds the most power in the middle rpm range, which is great for towing and steep grades. To make these headers last, Thorley made them out of durable 14-gauge mild steel with 3/8 in. thick flanges and 5/16 in. collector rings. To prevent leaks, these headers have an O-ring welded into the flange, in addition to the high-temperature gasket provided.
Old Jan 8, 2008 | 12:32 PM
04Z71SATX's Avatar
Im interested, any idea where you are in regards to san antonio? Are the collectors included?
i know my sig shows an obs but i have a 05 5.3 now.
Old Jan 8, 2008 | 01:10 PM
xlcooplx's Avatar
Sent you a PM a little ago Moze. I also tried to hit you up using the shoutbox on LS1truck. For some reason my account over there hasnt allowed me to log in since the site was redone. Anyways, get back with me since you didn't end up reusing them like before planned
Old Jan 8, 2008 | 01:17 PM
DamnYankee's Avatar
I'm about 4 to 5 hours from SA (Dallas area). And there is no collector...the tri-y design eliminates the need for a collector.
xlcoolplx has first dibs since he PM'd me first...plus I kind of owe him...
Old Jan 8, 2008 | 06:27 PM
Casper's Avatar
Put me third in line.
Old Jan 8, 2008 | 07:27 PM
DamnYankee's Avatar
Headers are sold - thanks guys.
FlyingLow
Nov 24, 2015 10:05 AM
Superman09
Sep 25, 2015 05:55 AM
turbo truck
Sep 2, 2015 09:58 PM
