How to disable traction control
Old 02-29-2008, 10:41 PM
Stoichiometric's Avatar
Default How to disable traction control
My 01 has traction control with a DBW throttle. I would like to disable the traction control all together. The button or switch on the dash resets to ON every time the truck starts up, so I would like to reverse that operation. I think SLP made something for the F-body that did this. Does anyone know how the traction control system operates and have any suggestions for defeating it?
Old 03-01-2008, 08:30 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
There was a post a while back about it, I don't recall the solution but I'll bump this ttt!
Old 03-01-2008, 07:55 PM
Onyx 02's Avatar
I was told a long time ago that there's a procedure to disengage it. They said it was in the owner's manual, I think. I never did this to mine, but will try and find the post.
Old 03-01-2008, 08:35 PM
Thanks, I appreciate it. I'll look for my owners manual, I don't remember if I got one when I purchased the truck.
Old 03-01-2008, 08:53 PM
Onyx 02's Avatar
Procedure in owner's manual:
1. Park the vehicle with the ignition off and the transmission in PARK.
2. Turn the ignition to RUN; do not start the engine.
3. Apply the brake pedal, press the accelerator pedal to the floor and then press the TAS on/off button and hold it down for at least six seconds.
4. Release the TAS button and both pedals.
5. Turn off the ignition and wait a few seconds.
The next time you start the vehicle, the TAS will not automatically come on. You can restore the automatic feature by using the same procedure.
Old 03-01-2008, 09:23 PM
trever1t's Avatar
that is fugging way cool!
Old 03-01-2008, 10:49 PM
Thank you very much!
Old 03-01-2008, 10:51 PM
EXTREME's Avatar
wow, i never knew you could do that
Old 03-01-2008, 11:01 PM
Parke10's Avatar
i wish i had or could put it on my truck
Old 03-02-2008, 09:58 AM
formerly 1BADC10 (12/14/2011)
95ImpSS's Avatar
Interesting... never knew that.
Quick Reply: How to disable traction control
