Magnacharger Radix 112 kit
This is a perfect condition used kit that has less than 10k miles of use. I have all the parts available to make this kit fit early (return fuel + egr) or late model (returnless) trucks. Comes with a 3.2" pulley installed. You will need only a few items that you can choose based on your desired power level; a walbro fuel pump kit from Magnacharger, Texas Speed or none if your truck is flex fuel. Injectors, go for 60s if you are planning 500+ HP (you probably do not need different injectors for flex fuel trucks). I would recommend a custom tune to get the truck dialed in.
I modified the J-tube to accept the 90mm ls2 style throttle body, this is the best upgrade for this kit, expect 1lb of boost increase over the 78mm throttle and a serious top end HP increase. I can also include a plate that allows the use of the stock 3 bolt style 78mm throttle. I also built custom brackets for the heat exchanger that bolt it directly to the front radiator support bracket. I will also include the standard Magnacharger brackets if you wish to use those instead. I will include the K&N filter and Magnacharger air intake tube which are both brand new and never been used. Check out the pictures and if there are any questions feel free to ask.
Asking $3100 plus shipping.
I'm sure it would run great
