Garage cleanout sale...buy this crap or it goes in the garbage
Old Jul 29, 2008 | 08:13 PM
thunder550's Avatar
High on diesel fumes
Default Garage cleanout sale...buy this crap or it goes in the garbage
Any reasonable offer will be considered, I need to get rid of all this crap.
7 pin round to 4 pin flat trailer wiring adapter. $8 shipped **SOLD**
Misc assortment of AN and factory style fittings. I don't want to ship these out individually. $40 shipped takes it all.
(1) -4AN hose end coupler
(1) -4AN hose end coupler (hose cover only)
(1) 3/8" pipe to -6AN 90*
(1) -6AN hose end coupler (hose cover only)
(1) 3/8" pipe to -6AN straight
(1) -6AN female to female straight coupler
(1) -4AN female to male 90*
(1) -4AN female to female coupler
(1) 1/8" pipe female to -4AN male 90*
(3) factory trans-style fittings with clips
(1) trans cooler in radiator fitting without clip
(2) clips for factory oil cooler fitting in radiator
Two lengths of -8AN steel braided line. One is 8ft and one is 15 inches. $35 shipped.
KC backup floodlights. I had these mounted under my rear bumper for awhile. $20 shipped for lights and brackets. No wiring included.
Autometer fuel pressure gauge, never used. The included sender works intermittently. Wiring harness has been cut - gauge side is intact with a decent length of wire attached, but sender side is gone. $20 shipped. **SOLD**
Brake master cylinder and reservoir for a hydroboost truck. $15 shipped.
Rebuildable truck alternator. Charges but voltage fluctuates. Could be a bad diode or whatever straightens the AC current into DC. I believe it's a 130amp. $40 shipped.
Wiring harness specifically for a QTP electric cutout. Includes momentary switch, power plug, and connector. $10 shipped. **SOLD**
Stock coil brackets and heater hose holder. Bolts for coil packs are included. $15 shipped. **SOLD**
Truck knock sensor harness and one good used knock sensor. $20 shipped. **SOLD**
Two air filters. Both are 4" ID. $15 each shipped or $25 shipped for the pair.
Front coolant crossover and rear plugs. $15 shipped. **SOLD**
Hypertech 180* thermostat for separate housing/t-stat style water pumps. $20 shipped.
Stock truck oil pan, good shape except for hole drilled and tapped for turbo oil return. Can be plugged easily. $30 shipped. **SOLD**
Stock headlights for 99-02 Silverado and 99-06 Tahoe and Suburban. $40 shipped. **SOLD**
TWO electric fans, roughly 12" diameter. I know there are 3 pictured, but one is already promised to a friend. $25 each shipped. **SOLD**
Stock kick panels from my 01. $15 shipped. **SOLD**
Stock jack bracket and jack tools clamp from my 01. $15 shipped.
Stock front and rear driveshafts from my truck ECSB 4wd, along with stock tranny crossmember.
$40 shipped for front d-shaft
$40 plus shipping for rear driveshaft **SOLD**
$30 shipped for crossmember.
2 stock truck water pumps, pre-05 style with integrated thermostat and housing. $40 each shipped **1 SOLD, 1 LEFT**
Also have a stock fan clutch, $25 shipped.
Old Jul 29, 2008 | 08:14 PM
thunder550's Avatar
Gas pedal and bracket from a hydroboost truck. $25 shipped.
Brake pedal and cover, fits vacuum booster truck. $15 shipped. **SOLD**
Alternator/power steering bracket. $30 shipped. **SOLD**
Fan shroud, fits 27" radiator. $30 shipped.
Vacuum brake booster, $30 shipped.
Brake master and reservoir for vacuum booster. $20 shipped.
Non hydroboost power steering pump and lines $20 shipped.
Stock EGR valve and tubing $20 shipped.
Plate that goes under stock airbox $10 shipped.
Radix accessory bracket with tensioner $30 shipped. **SOLD**
Door strap, $20 shipped.
Transfer case input gear for 4L60E $15 shipped
2 of the fuel rail blocker thingies from the back of the head $10 shipped for both
Truck A/C bracket and tensioner $25 shipped **SOLD**
Stock valve springs, $5 for shipping.
U-bolt exhaust clamps, set of 4 $20 shipped
Stock corner lights for 99-02 Silverado 99-06 Tahoe/Suburban $15 shipped
Three serp belts, $15 shipped each or $30 shipped for all
25-06117
1130K6 6PK2870
1110K6 (I think) 6PK2820
Stock air deflector/plastic skid plate from behind the bumper 99-02 Silvy and I think probably 99-06 Tahoe/Suburban too $15 shipped **SOLD**
OEM Z71 front shocks approx 8k miles I think. $40 shipped **SOLD**
Chrome mirror caps $30 shipped
Random assortment of plug wires and metal boots.
6 plug wires, 4 are napa brand, 2 are OEM
looks like 15 plug boots
$20 shipped for the 6 plug wires
$20 shipped for the 15 plug boost
$35 shipped for all of it.
Transmission electronic thingy $30 shipped
1 rear O2 sensor $10 shipped
Old Jul 29, 2008 | 11:39 PM
BigTex's Avatar
$70 shipped for Truck A/C bracket, Radix bracket and one electric fan?
Old Jul 29, 2008 | 11:44 PM
thunder550's Avatar
Well I'm all out of e-fans unfortunately (forgot to mark them sold), but I'll do $45 for the two brackets.
Old Jul 30, 2008 | 09:41 PM
53RUSSELL's Avatar
Chris I’ll take the truck pan will that fit a 5.3?
I'll give you call tomorrow.
Old Jul 30, 2008 | 09:55 PM
silveradokidd_4518's Avatar
damn you have a lot of crap lol
good luck with everything man!
Old Jul 31, 2008 | 10:07 AM
thunder550's Avatar
Yeah it will fit any of the LS based engines. I still have the fan I promised you a long time ago too
Thanks, this is a couple year's worth of parts that have built up in my shed
Old Jul 31, 2008 | 11:20 AM
sharpshooter's Avatar
What brand air filters are they?
Old Jul 31, 2008 | 12:20 PM
Elec87's Avatar
Do you have a complete truck accessory system? I would be interested in that and the trans/electric indicator switch...
Old Jul 31, 2008 | 03:05 PM
babydeuce's Avatar
PM sent on Gauge.
Jack
