1999 ls1/6spd. swapped sonoma FOR SALE
like the topic says i have decided to sell the truck... this setup only has about 30 miles on it...
this has taken me 2 years to complete nothing has been halfassed....
1999 standard cab stepside bed pewter in color 83,000 miles clear clean title
4 cylinder automatic truck from the factory
has black fender and black cowl hood
flush mount fiberglass bed cover with battery located in bed
grille headlights and airdamn for a 1997 model
8 point cage
bucket seats out of blazer
new black carpet
airfuel/ nitrous gauges on a pillar
prostars 15x8 on the rear with 275/60 nitto drag radials
15x3.5 on the front
truck has 2" drop spindles 2" drop leafs toxic shocks all the way around
zq8 swaybars
10 bolt setup with new bearings and new eaton posi unit 4:11 gear
lakewood traction bars designed for a s-10
the motor has been completely gone threw
2000 block and rods and pistons
crankshaft was turned 10-10
arp stud kit
clevette bearings
tsp ported oil pump
double roller timing chain
new set of stock rings
Comp Cams XE 228/230/571/573 LSA 112
tsp harden pushrods
patroit gold valve springs
ls6 intake
car shop inc. alt. only front accessories set up
tranny has also been all the way threw
all new bearings
3rd and 4th gear
3-4 slider
carbon fiber syncos.
steel shift fork
brass shift fork pads on all the forks
billet slider keys
filled with royal purple syncomax
ls7 clutch kit with new slave cylinder
all new fuel lines ran 6an with mallory fuel pressure regulator and a wallbro 255 in the tank..
radiator is a all aluminum 3 core with 2 electric fans
custom made cold air intake with silcone elbows and piping ran to where the battery use to be with a k&n filter.
phill smith made the wiring harness only thing that doesnt work in the fuel gauge and the temp guage
only thing this truck really needs is the hood fender and bumper painted and it would be a awsome truck.
only reason i am selling it is because i am starting a new project so this one has got to go.. i know there is alot of stuff im forgetting but this post is long enough i will have pics of it tomm
$10,500 OBO may due some trading so let me know what you got...
located in ashland ky.
call 606-465-0013 for more info... thanks anthony
8 point cage
new black carpet
15x3.5 on the front
zq8 swaybars
arp stud kit
clevette bearings
tsp ported oil pump
tsp harden pushrods
ls6 intake
all new bearings
3rd and 4th gear
3-4 slider
steel shift fork
billet slider keys
12 Second Club
I've seen, and lended a helping hand on the build of this truck. it's definately done right...
paint match the hood and fender, and it would look just fine.
if I'm not mistaken, I think this truck has a set of long tube headers on it as well as a custom y-pipe, exhaust cut-out, 3" SI/SO flowmaster and a single over the axle pipe in the stock location.
given the amount of time and money put in to this project, it's worth the money IMO...
