02 ls1 into 05 v6 silverado.
Well it is now time for me to start the project i have been dreaming of since i was 14 years old. I finally stumbled across a deal that i couldn't pass up. here is a quick overview of the project... but first i would like to let you guys know... this project is my daily driver and will be seeing a good amount of track time.... but more driving around campus... i go to Texas Tech!!! Wreck EM'! anyways back to the project...
Vehicle: 2005 Silverado 1500, Regular Cab, Short Bed.
Current Engine: 4.3L v6
Current Modifications: McGaughy's 4/6 Spindle Drop, Painted stock rims, air intake and exhaust.
_______________
Swap information:
all below parts are out of a 2002 Ram Air T/A with only 36,000 miles on it.
Parts already acquired:
now i need some major input on what i still need... i thought i knew everything and turned out when i was ready... i didn't lol.
So far what i can think of are the below items
I know there are things i am still forgetting.. please chime in.
a few questions:
and I am sure i still have more questions... i will update as they come to mind.
The following are pics of the truck the engine is going into... and also the engine and transmission
thanks for the help! and i cant wait to start the ball rolling on the dirty work!
Preston
_______________
Swap information:
- 2002 ls1... complete from intake manifold to cat's
- 4l60E automatic transmission
- wiring harness
- AC Condensor
- Stock T/A Air box
- Misc Hard Lines and soft hoses
- computer
- almost anything you would see if you opened the hood of a stock ram air T/A
- long tubes
- frame mounts.... the engine mounts are still on the engine
- x pipe
- im not sure on the whole DBW or DBC throttle body situation
- upgraded fuel pump?
- fuel lines?
- air intake set up
- oil cooler
- truck tranny pan
- truck pick up tube
- Vette fuel filter/regulator
a few questions:
- With all the wiring harness situation.. should i use the T/A harness or take a truck harness and cut-and-wire to the injectors?
- can i run it on the f-body tune until i can afford a nice dyno tune? or would that be asking for trouble?!
Preston
click on the pics and they get bigger..... i just spray painted them.. they turned out good but im gonna have them powdercoated.... back to the swap
SPAM HUNTER
dont have to worry about removing all the old cable stuff, replacing the old cruise control with the tac module, also the multifuntion switch has to be replaced...just more and more money that doesn't have to be spent.
Dustin
Dustin
