Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > TRUCK PERFORMANCE & GROUP DISCUSSION > Forced Induction
Old 02-01-2009, 08:08 PM   #1
TrickPerformanceProducts
Trader Rating: 4
Truck Sponsor
Talking Twins and not what u'r thinking. hint TVS 3800.
Well this build was pretty special. took me almost 5 months to build, and wait on parts. Hope yall enjoy as much as I did building this.
Some will ask why?
the answer is Becuase.
We used dual 1900 superchargers 8rib 3" pulleys,
ATI 8 rib drive pulley at the crank.
Magnacharger got me 2 of these with the bypass controll valves on opposite sides. So free'd up the middle for the air box.
Intake is a billet piece with meth injection bar.
3/8npt for an air temp sensor, and dual 1/8 for boost ports.
intercooler 3.5" 3 / 3 in and out -10 fittings.
Custom fuel rails and rail brackets
Upper plenium is made up of 3/8,1/2, and 1/8 aluminum. It was bolted together then welded out.
Air inlet and rear plenium are modular so they can be expanded if room allows.
Front drive mounting plate is 1/2 aluminum. Tentioner is an off the shelf part I modified to expect ATI's idler pulley.
Rear blower inlet area
Billet intake
Lots more intake material. also billets for main blower idler.
18+lbs ligher. lol
8rib - 1/2 main plate - dual belt system Blower belt is wrapped onto other side of idler pulley to help any loading on the water pump shaft.
Spring loaded tentioner
Main idler,
you can see there also a provision for another idler on the main bracket. We did not need it in the end, but its there.
Altenator relocation bracket. had to swing the altenator over to clear the top air box and blower.
__________________
Front mount turbo kits.
Starting at 2000.00
Electric fans with shroud. Start @ 160.00 + frt.
Angel of the 1 off!
TrickPerformanceProducts is online now   Reply With Quote
Old 02-01-2009, 08:11 PM   #2
Mr. Sandog
Trader Rating: 0
Mr. Sandog's Avatar
Nifty. Does it run?
__________________
LS2 wrapped in an SUV
Mr. Sandog is offline   Reply With Quote
Old 02-01-2009, 08:12 PM   #3
tarinitup
Trader Rating: 8
11 Second Truck Club
tarinitup's Avatar
Looks great. Lot's of $ in there!
__________________
Turbo GMC 11.09@120
Nelson Performance 91mm Kit
http://www.youtube.com/watch?v=QzrBQisHMyI
tarinitup is offline   Reply With Quote
Old 02-01-2009, 08:13 PM   #4
Truckshop
Trader Rating: 15
2004 GMC Sierra 1500
Truckshop's Avatar
That is sick!!!!
__________________
Shelton
04 GMC Crew Cab 6.0 TR224 PRC Stage 2.5 Heads Pacesetters W/ORY Electric Fan CAI UDP TBSS Intake Swap
Truckshop is offline   Reply With Quote
Old 02-01-2009, 08:13 PM   #5
BigCountryx
Trader Rating: 3
BigCountryx's Avatar
HOLY SHEIT!!!! Trickest of the trick!
__________________
06 Silverado SS, Unnaturally Aspirated
BigCountryx is offline   Reply With Quote
Old 02-01-2009, 08:18 PM   #6
Low_LSX
Trader Rating: 33
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
Send a message via MSN to Low_LSX Send a message via Yahoo to Low_LSX
Damn I want one.
__________________
A.J.
Coming soon
2000 GMC Sierra RCSB
.............. - Action Speed & Machine LSX 376 - ARP - Meziere WP319S - DBRODS Custom Fuel Cell - PatrickG Custom Cam - Nasty Performance Coil Relocation Bracket - Ron Davis Radiator - ARH 1-7/8 - 3' X Pipe with Dual Magnaflow Mufflers - 4l80e - B2 Circle D Converter - L92 Vic Jr - Intake Elbow - 90MM UMI - QA1 Adjustable - LS Water Vapor System Made by Kurt Urban Performance - 4/6 DJM - CalTracs - Boyd Coddington Starburst.
Low_LSX is offline   Reply With Quote
Old 02-01-2009, 08:18 PM   #7
dirt track racer 81
Trader Rating: 12
TOTM JULY '07
dirt track racer 81's Avatar
Send a message via Yahoo to dirt track racer 81
all i can say is wow. how much boost is this going to run? could this be a future kit for sale? what keeps the blower pulley thats over the water pump pulley in place?
__________________
-Tyler Daily Drivin 2000 White ECSB Truck 370-244/248 .612/.615 112 lsa-L92 Heads Milled .030-Victor Jr.-Fast 1375cfm 4150 throttle body
dirt track racer 81 is offline   Reply With Quote
Old 02-01-2009, 08:24 PM   #8
turbomax
Trader Rating: 0
wow thats sweet
turbomax is offline   Reply With Quote
Old 02-01-2009, 08:28 PM   #9
WJ MARK
Trader Rating: 7
WJ MARK's Avatar
you forgot to mention that its a 427 LSX block
I think Rick said its going to be pushing 20 lbs. of boost
__________________
2001 SILVERADO ECSB Z71, 3-4 drop ,TRICK PERFORMANCE TURBO,stock LQ4, FLT lvl.5 4l65e
WJ MARK is offline   Reply With Quote
Old 02-01-2009, 08:34 PM   #10
nlawson6.0
Trader Rating: 24
nlawson6.0's Avatar
nice work!!!!!!!!
are u expecting issues with heat?
-Nate
__________________
2001 RCSB 4x4
nlawson6.0 is offline   Reply With Quote
Tags
3800 , tvs , tvs3800
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
