Smell your coolant overflow cap.
Does it smell like combustion gases?
If it does and you were not losing water then I would say you would be pushing water.
Btw you combustion chambers look pretty good jus a little rich though.
__________________
01 ECSB 8.8to1,4.8l,Front mount ,Blow through 2.3l twinscrew,cleaned up241's,LT's,custom 212/218,
(Haulin' azz with all the wrong parts!)
Suffering from a stripped 4.10 ring gear.
98 Z28 Project 3520R.W. MAC mids,cai,Lil suspension12.7@111 street tires (The sleeper)
my over flow tank was almost empty and this side of the motor has been wet for awhile. i thought it was oil until i smelled it one day. also are the bolts suppose to stink when you pull them? mine smelled almost like gear oil.
there is a spot in my tune where it gets pretty rich i've been working on it. its at about 40% throttle and 5-6 psi at about 2000 rpm. it will hit 9's afr. i think i got it though. its hard to tune it perfect around the meth but i'm getting there.
i cant see the pics mike. email them to me. i know your trying to keep this affordable but, i would just replace the lifters anyway.
__________________
2007 silverado classic ecsb 2wd 5.3. flex fuel. curb feelers and fuzzy dice.
lingenfelter gt-1 cam, ls6 springs, aem brute force dry flow intake, aem brute force long tubes, true duals with x-pipe and magnaflows, yanktt3000, lc-1 hp tuners
P&P heads, HD2 shift kit and servos that have been waiting to be installed for months now...
I would just replace them especially if you think you had coolant in the oil. They gum up and stick down causing the tick. Based on the combustion chambers and piston tops I think your head gaskets were good. Coolant in there cleans them out and you would definetly notice it. Did you look for traces of coolant in the center bolt hole?
__________________ 2005 5.7 Z71 SS ECSB
Old E.T. 13.41 @ 100.4 1.97 60ft W/ 5.3 & 112
Magnacharger Radix 122, 90MM LS2 T.B.,2.8 Pulley, Forged 6.0, Greg's Custom Engines 317 heads, A & A Corvettes stage III cam, Harland Sharps, OBX Stainless Longtubes, Magnaflow 15838 SS exhaust, Vara Ram C.A.I., 2 Bar SD HP Tuners, and a few other things.
lifters are on there way will be here today. i just wanted to make sure i didn't waste my money. center bolt had water so did a few others. but i have the long bolt style block. early 2004 i guess. the smelled bad too. almost burnt smelling. like old gear oil.
Do your heads have this marking? This is where to look for a clean spot from coolant leak. I just don't want you to bolt back on bad heads and have the same problems.
I know it's more work, but with the noise I heard on your vid, I'd go ahead and pull the other head off too, just to have a look at old number 7. It's more of a pain, but since you really didn't find anything definite, i think it would be best, since the last thing you want is to put it back together and have it still making that noise. Ya, know what I mean?
__________________
01 ECSB, Forged 5.7 LS1, 4x4, GMC: 12.21@110.5 at 4800' (DA 7000')
KB Racing S480 Turbocharged!
FULL Line of EFILive and Innovate Products!!!
AUTHORIZED Master Power, BW Airwerks and Turbonetics Dealer!!!
PM or Email for details Kbracing96@gmail.com
