Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > TRUCK PERFORMANCE & GROUP DISCUSSION > Forced Induction
Old 06-14-2009, 07:25 PM   #1
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
Default 4.3l turbo budget build updates
this has been an on going project for about 10 months or so now. we finally got the turbo on and some tuning done.
the build is a built low compression 2000 4.3l with port and polished vortec heads. we used syty manifolds and a mpt70 turbo. we installed a marine intake with 60# injectors. also swaped the old style pcm for a 0411 pcm for 3bar tuning. we are currently runing 6psi. our goal is 15-20psi with meth. here are a ton of pics. i will try and label them as i go. remember this was a budget build, so we got things where we could. the marine manifold was only 199 on ebay. i took some pics of the way i installed it too.
here is a over view pic
here is a pic of the driver side manifold
this is the wastegate with its down pipe
custom intake!! yes pvc!
my wonderful 3" downpipe.
little different angle of downpipe
random pic of the manifold
extremely cheap BOV and junk yard e-fans
driver side of IC
passenger side of IC
IC piping to turbo
another angle of same part
better pic of wastegate and downpipe
this is the turbo t3-t4 adapter
__________________
'04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, SC3200 yank, FLT LVL 7 4L60E, 5.3L, ls6 heads, lsg cam. 12.33 @110mph
http://www.streetfire.net/video/turb...mph_741849.htm
4.3l budget build http://performancetrucks.net/forums/...d.php?t=442854
TURBHOE is offline   Reply With Quote
Old 06-14-2009, 07:31 PM   #2
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
this is a pic of the filter behind the inner fender area
we used the stock airbox tube to adapt to the manifold the stock thing would not stay on for anything
left over crap!!
this is the wonderful boost gauge and wideband display. this is not its final spot we are doing things as money comes in.
this one we installed the upper radiator hard line and thermostat. we did not have to modify anything here just installed it like stock.
this one is the heater core hose off the manifold with out having to drill or tap anything.
this one goes to the water pump itself. there was a plug here we just removed it and srewed in an adapter from advanced.
__________________
Old 06-14-2009, 07:38 PM   #3
vanillagorilla
Trader Rating: 1
vanillagorilla's Avatar
Send a message via AIM to vanillagorilla
So you were able to use syty manifolds without modifying them? What about the cross over tube, did it clear the oil pan and power steering pump?
__________________
2000 ECSB-The case of the mysterious bent axle
1992 Typhoon-almost, mostly, sort of, kind of stock
1969 Mullet-Mobile-too much work
vanillagorilla is offline   Reply With Quote
Old 06-14-2009, 07:39 PM   #4
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
now this is not the final product he is going to clean some of the stuff up and relocate a few small part. like the boost gauge what not. with just 6psi it pulls hard its actually kind of amazing. its pretty cool. some of the charge pipes are from a sts kit. others came with the IC. the down pipe and exhaust is left over parts from here and there. turbo came from kbracing. the wastegate is from a used sts kit.
__________________
Old 06-14-2009, 07:43 PM   #5
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
Quote:
well at first we thought we were screwed. but then we flipped the cross over around and sure enough it worked good. we had to cut off the random metal stick that comes up off the driver side motor mount. we had to cut it down as low as we could. we also had to bend the power steering pump line that curves around the back of the pump. it was in the way of the manifold itself. later we plan to replace it with just a braided line. other than those two things it worked great.
__________________
Old 06-14-2009, 09:39 PM   #6
1BADAZZSS
Trader Rating: 8
Looks like fun. Got any sound clips?
__________________
6L,turbo'd, cammed,80e, E85
1BADAZZSS is offline   Reply With Quote
Old 06-14-2009, 10:08 PM   #7
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
http://videos.streetfire.net/video/4...lsa_689221.htm
its just a idle clip for now
__________________
Old 06-15-2009, 03:09 PM   #8
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
i'll try to get a better video later on.
__________________
Old 07-18-2009, 01:51 AM   #9
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
A little update, we were playing around with a buddy with a hemi ext cab ram truck. it has longtube headers, true dual 3" exhaust, intake, tune. the silverado was running 6psi shifting at 4500rpm due to fuel pump not having enough fuel above that. when he shifted to 3rd it blew the clutch apart. funny thing is we were walking past the hemi. it was great. now he has a spec clutch, the guy said it should hold around 700-750fly wheel ftlb.
now we need to get the pump installed the 60's were at 110% duty cycle by 4500 rpm. fuel pump couldn't handle 4.3l with 6psi. pretty sad.
__________________
Old 09-07-2009, 12:53 AM   #10
f4tal
Trader Rating: 5
f4tal's Avatar
any update yet??
__________________
2002 RCSB 4/7 drop, E-fans, Tune/ H/C/NX 5.3 build in progress
f4tal is offline   Reply With Quote
Tags
2002 , 43 , 43l , 48 , 48t , chevy , cross , forum , kit , pipe , silverado , streetfire , sts , tahoe , truck , turbo , vids
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
