FS: TVS2300, IW/LeftCoast 8 rib pulleys, Edelbrock 90mm throttle body
High on diesel fumes
I am done with this truck, lost the patience for repairs. Parting out. Please do not junk up this thread asking why, if you have questions PM me. Also, please do not call dibs on any other parts that I may have on the truck. When I am ready, I will list them for sale separately.
Note: Prices below do not include shipping
First up: Magnacharger TVS2300, front inlet/rear drive $6000 ***sold***
Rear pulleys are cog drive, overdriven, front pulley is 10 rib 3.2" (will work fine with a 6 or 8 rib belt). Makes 14 psi on my 403ci motor.
Includes: blower unit, 60# injectors (shorty with LS1 style connectors), intercooler pump/reservoir/heat exchanger, fuel rails (set up for EXTERNAL regulator - no provisions for factory FPR). I will toss in my home made throttle cable bracket if you are putting this on a cable TB truck. I will include my already modified water pump (without a thermostat or housing). I have valley covers for both LS1 and LS2 style motors. I DO NOT have the Magnavolt that was supplied - sold that awhile back. This was originally an LS2 SSR kit, so included mounting brackets and air intake tube are for that truck. I will also include my 5" mandrel bent stainless intake tube that I had made (if your application is the same as mine), and the AirAid cold air box that I am running. Blower has approx 8000 miles on it. Edelbrock 90mm cable throttle body (with TPS and IAC valve) is also available for an extra $250. My Edelbrock FPR and various AN lines are available for another $100. If you want it, will include -8 to 2 -6AN Y block, -6AN lines to back of fuel rails, -6AN lines, to FPR, and -6AN line that you will have to hook into your stock return line.
LeftCoast32/Innovators West 8 rib pulley kit $1000 ***sold***
Includes heavy duty tensioner, 8" overdrive crank pulley, alt pulley, p/s pulley, two idler pulleys, and I'll throw in the two belts that I have for it.
read his original post! lol
Bump for an awesome setup
