Click here to visit LS1Tech
LS1Tech Wiki
Go Back   PerformanceTrucks.net Forums > TRUCK PERFORMANCE & GROUP DISCUSSION > Forced Induction
Old 10-11-2009, 09:37 PM   #41
parish8
Trader Rating: 2
single digit dreamer
parish8's Avatar
thanks for the heads up on that intake/injectors. we are going to go ahead and do that swap. seems to me with this intake swap, some slightly larger injectors and the meth we are in business to make some decent power safely.
anyone know if that intake uses the short injectors. i have a set of what i think are 38's. they have that same style of plug on them but are very short. it would be sweet if they are the same style and i can use these 38's.
__________________
09 G8 gt
twin 60's, alcohol injection kit, dr's on stock 18's. 477hp/504tq(10psi), 11.44@124.5(11psi)
dual 3" exhaust. 563hp/570tq(10psi)
circleD converter, patrickG spec cam (216/224 .561/568" 115LSA +2 advance). 635hp/600tq(10psi), 11.42@125.3(8psi)
http://neufamily.org/images/g8gallery/
parish8 is offline   Reply With Quote
Old 10-11-2009, 10:19 PM   #42
exodus
Trader Rating: 11
exodus's Avatar
Send a message via Yahoo to exodus
Default I agree
Quote:
Originally Posted by GMCtrk View Post
Parish Turbosports. Great name recognition due to your reputation.
This is the winner for sure!
__________________
2005 5.3, 122HH Intercooled Radix, twin billet 100mm idlers, 3.1 pulley, ported and polished matched 90mm TB and J tube by WCCH, 60# injectors, 2004 ZO6 Cam, GM heavy duty roller timing set, TSP ported oil pump, Comp Hardened pushrods, Patriot Gold dual valvespring kit, Arp fasteners, FLT level 4 4L60E, Yank SC2800 converter, 05 E fans, Magnaflow high flow cats, Flowmaster 40, 32" NITTO Terra Graplers
http://www.performancetrucks.net/for...d.php?t=455832
exodus is offline   Reply With Quote
Old 10-11-2009, 10:20 PM   #43
junk racing
Trader Rating: 0
Registered User
sounds like an awesome build. I believe the injectors are the same height as say a ford/accel style injector.
__________________
03 S10 RCSB V6 lowered on Coys-The daily
95 S10 5.3 build in progress..
junk racing is offline   Reply With Quote
Old 10-11-2009, 10:20 PM   #44
exodus
Trader Rating: 11
exodus's Avatar
oh, and i would most definetly do the intake swap as well...mainly for reliability and safety.
__________________
Old 10-11-2009, 10:49 PM   #45
A Low Dime
Trader Rating: 13
A Low Dime's Avatar
Send a message via AIM to A Low Dime
Im not 100%, but I believe the car injectors fit.
I dont think this will help, but I wanna post it.
__________________
Brendan
Just Installed 224/230 112 Custom Grind-K/N FIPK-Marine Intake Manifold Swap
P/P LS1 TB-NX Kit-LS1 Electric Fans-Upgraded Y Pipe-Tuned-Built Trans-Shift Kit-Stock Converter
3.73's-Zexel Torsion Unit-Coddington 17's-275/40/17 Nitto 555r's
A Low Dime is offline   Reply With Quote
Old 10-12-2009, 11:22 AM   #46
f4tal
Trader Rating: 5
f4tal's Avatar
im pretty sure ^^ hes right!
the intake is a much better way to go if your running boost. only bad thing is it weighs 58 pounds. lol its like a f**kin boat anchor no joke! i would go with some 42lb injectors though... just my $.02
__________________
2002 RCSB 4/7 drop, E-fans, Tune/ H/C/NX 5.3 build in progress
f4tal is offline   Reply With Quote
Old 10-12-2009, 12:55 PM   #47
hellbents10
Trader Rating: 10
LS1Tech Sponsor
hellbents10's Avatar
Yeah the stock fuel system is not that much fun to work with. I have made over 300whp twice with 4l60e blown S10's with an FMU no meth and pump fuel. About 95psi of FP and you can make 300, just not that reliable. With a marine intake or 2114 you can make 350+ to the tires and drive it every day with the stock engine.
__________________
TJ
[SIGPIC][/SIGPIC]
616-837-8975
hellbents10 is offline   Reply With Quote
Old 10-12-2009, 02:15 PM   #48
1989k1500
Trader Rating: 11
1989k1500's Avatar
Send a message via AIM to 1989k1500
Depending on meth for fueling, eesh. Thats cool until it quits on day and the motor goes to 15:1 AFR in boost. lol
__________________
-Luke
01 rcsb Z71, lowered, 6.0 LQ9, p&p 241s, cam, LPP LTs, PI3600, etc.... - SOLD
1989k1500 is offline   Reply With Quote
Old 10-12-2009, 04:54 PM   #49
parish8
Trader Rating: 2
parish8's Avatar
Quote:
i depend on a lot of components to work as they should and if they dont things blow up. it's just the way it is. loose something simple like a vacuum/boost line and boom it can go.
on my car and i am hoping on this truck i can use the iat sensor is a way to make sure the meth is flowing and if not pull a ton of timing when the iats go up.
__________________
09 G8 gt
Old 10-13-2009, 01:26 PM   #50
TURBHOE
Trader Rating: 3
TURBHOE's Avatar
i didn't read the whole thread yet but i can tell you i just did a build like this on a silverado. its making well over 300whp. we took it to the quarter mile. the 5speed popped out of gear on the launch so the time sucked but he ran at 102+mph after he put it back in gear and took off. with the clunky nv3500. this was a 2wd extcab short bed silverado. on our build we built the motor itself and used the marine intake. it was a easy swap NO drilling required if you do it right and the manifold we bought came with everything. including injectors (that we didn't use). and the siemen deka 60's with the ls1 style plug fit right in there. and you can use a ls1 throttlebody on it. for the ease of swap and the performance gains you get i would go for the intake for sure.
alot of people don't know that you can put the 918 springs on those heads without having to do any machining. that way you have stronger springs for boost and can run a higher lift cam with out worry.
we also used syty manifold and a mpt70 turbo. 14psi and the 60's are maxed out and its walking from my buddies 350z with a 75shot.
http://videos.streetfire.net/video/4...ado_705885.htm
and this is his daily driver. infact he just took a trip to tennesse from maryland and down to florida.
http://www.performancetrucks.net/for...d.php?t=442854
__________________
'04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, SC3200 yank, FLT LVL 7 4L60E, 5.3L, ls6 heads, lsg cam. 12.33 @110mph
http://www.streetfire.net/video/turb...mph_741849.htm
4.3l budget build http://performancetrucks.net/forums/...d.php?t=442854
TURBHOE is offline   Reply With Quote
Tags
43 , kit , manifolds , mpg , nv3500 , parish , parish8 , s10 , silverado , sonoma , sy , truck , turbo , ty , v6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
