Garage cleanout sale! Lots of misc engine parts.
Old Nov 3, 2009 | 05:17 PM
thunder550's Avatar
High on diesel fumes
Default Garage cleanout sale! Lots of misc engine parts.
Prices below do not include shipping. Please send your zip code for a shipping estimate.
Set of 4 3" exhaust u-bolt clamps $15
K&N air filter. Short one is a K&N with a 5" opening $20. Tall one is sold.
Window motor $15
Stock fan clutch $15
Hypertech 180 thermostat for later model water pumps with separate t-stat and housing $15
A/C compressor bracket - $10
Stock motor mounts - $40
Stock timing cover - $30
Knock sensor - $20
Knock sensor harness - $15
Rollmaster double-roller adjustable LS1 timing set - $50
Truck oil pan - $40
Windage tray - $20
Truck oil pickup tube - $20
Trans cooler, $20
Stock rockers - $50
Stock front coolant crossover tube - $10
A/C compressor (the style without the plug in the back) - $50
Crank sensor - $15
Cam sensor - $15
Oil pressure sensor (tall style) - $15
7 good Taylor spark plug wires (red) - $40
I also have a metric ****-ton of factory bolts, let me know if you need anything and I'll see if I have it.
*edit - see below for pics
That's all I can think of for now, might add some stuff later.
Old Nov 3, 2009 | 08:23 PM
hirdlej's Avatar
How much do you want for the metric **** ton of factory bolts? What if I want ALL of them?
Old Nov 3, 2009 | 09:00 PM
Whippled2dr's Avatar
ARP reusable crank balancer bolt - $15
Is this New? Part#234-2503? If so I'll take it.
Also do you have any alternator bolts and power steering bracket bolts that bolt to the head (M10x1.5x115 i believe)?
Thanks
Old Nov 3, 2009 | 09:25 PM
iamkeniff's Avatar
i need starter bolts, the bolts for the tranny to hold it to the block, alt bolts, power steering bracket bolts.
Old Nov 3, 2009 | 09:30 PM
jetersaurous's Avatar
how many miles on the parts
Old Nov 3, 2009 | 10:41 PM
thunder550's Avatar
Ummm...no idea? $50 shipped for all? (see pic added above)
Thanks
It's not new, but it's in good condition. Not sure what the part number was.
Yes, I have all of those other bolts. See pic and description above.
I have starter bolts, 6 bellhousing bolts (one I shaved the stud off), two sets of alt bolts, and 9 p/s bracket bolts.
No idea.
Old Nov 3, 2009 | 10:53 PM
thunder550's Avatar
Bolts
Organized (this is 45 minutes of my life I will never get back)
Old Nov 3, 2009 | 11:14 PM
LsxCody's Avatar
What kind of tranny coolers are they
Old Nov 3, 2009 | 11:18 PM
thunder550's Avatar
Black ones.
Ummm...I think they are manufactured by Long MFG Co, which makes B&M, Tru-Cool, and some others.
Old Nov 3, 2009 | 11:22 PM
64CAMINO's Avatar
i want the bolt 4 rows up, 3 to the right.
