Turbo hot parts and intercooler
I am selling my Trick hot parts and intercooler setup.
The hot parts are all stainless steel and include my driver side factory manifold, crossover set up for a 44mm wastegate vented to the atmosphere, passenger side log manifold with v-band clamp to connect to crossover, standard 3" down pipe, and a 3.5" down pipe with a built in cutout. All parts are ceramic coated. With the upgraded down pipe and ceramic coatings I have around $3700.00 in the hot parts alone. If local pick up I will also include a Magnaflow 4" stainless exhaust set up for the 3.5" down pipe.
I am asking 1800.00 for the hot parts plus shipping. The hotparts come with a 1 year warranty from Trick.
My intercooler is the one TRT was selling. It bolts up to the frame rails behind the bumper no modification is required to mount it up. It easily mounts with two bolts. With this intercooler I would see temps around 11* above ambient when going down the highway. This also includes polished aluminum bead rolled charge pipes set up for the trick hot parts and a factory intake manifold. The charge pipes have a flange for a Tial 50mm blow off on them and a intake temp sensor. E fans will be required for them. This also includes all couplers and T bolt clamps. I have over $1000.00 in this set up.
I am asking $600.00 plus shipping
My brother is buying the truck and plans on putting a supercharger on it. I'm pulling the motor and tranny out, and will be putting them into an s10 with a new turbo. I don't have any use for the hot parts or intercooler now so they are getting sold.
As soon as they sell Trick and I will probably be doing a little something with the Camaro.
