FS: Front Mount Turbo setup
Old Jun 20, 2010 | 07:25 PM
Pirate109's Avatar
Default FS: Front Mount Turbo setup
For sale- a front mount turbo setup for 99-2006 5.3l. Unfortunately my plans have changed (and I was so close) so someone is going to get a deal.
Kit includes:
-Masterpower T-76 new never installed has a .68 AR hot side(easily changed)
-Custom mild steel hot pipes (was told by guy I bought them from same design as what Parish has used), 3in down pipe with cutout, passenger side log, flex pipe crossover, 2 O2 sensor bungs, pyrometer bung, wideband bung
-JSG 44 magnum wastegate and extra spring (lower boost) mounts to log and down pipe under hood with vbands
-42lb marine injectors
-New Bar and plate Intercooler, 27x12x3 3in inlet/outlet 2.5in from turbo to intercooler, 3in from intercooler to Throttlebody and piping with T-clamps, silicone connectors, reducers, BOV
-new K&N filter
-oil line fittings, feedline with restrictor fitting, return fittings , gaskets
There are a few misc nuts and bolts needed, return oil hose and vacuum line, and some intercooler plumbing to do so this is not a true bolt on setup. I never had a chance to install it but a little time and a good tune should get you around 450-500hp. Not going to split up -$2700
PM me and I will get back to you ASAP.
Old Jun 20, 2010 | 07:32 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
any trades
Old Jun 21, 2010 | 05:02 AM
Pirate109's Avatar
Bump.........no trades but negotiable price!!!!
Old Jun 22, 2010 | 08:48 PM
Pirate109's Avatar
Bumpity bump.. Lots of window shoppers, willing to entertain offers!
Old Jun 23, 2010 | 12:28 PM
chacho44's Avatar
Nice!!!!! wonder if it will work with my 6.2swap on a vehicle though
Old Jun 25, 2010 | 04:53 PM
Pirate109's Avatar
Bump.. willing to go to $2300. this stuff has got to go.
Old Jun 25, 2010 | 05:32 PM
anheuserbusch08's Avatar
i wonder if itll fit an s10 with a 6.0 .... clearance issues????
Old Jun 25, 2010 | 09:10 PM
Pirate109's Avatar
I couldn't tell you about clearance problems on an s-10 but I'm sure someone has done something similar. thanks for looking.
Old Jun 26, 2010 | 10:41 PM
bigred06's Avatar
i stay in los angeles im willing to give you $2000.
Old Jun 29, 2010 | 05:49 AM
Pirate109's Avatar
Bump... still available.....stuff has got to go
