heads, eng parts, blocks, converters, efans, harness, etc...
Old Feb 14, 2011 | 12:51 AM
bluecajun5.3's Avatar
11 Second Truck Club
Default heads, eng parts, blocks, converters, efans, harness, etc...
Doing a shop clean up. Posting up what I have at the moment off the top of my head. Working offshore right now so i don't have any pics at the moment.
Lance
Lowered prices and SOLD parts in red
These 3 listed parts came off of an 04 lq4 (6.0L) with 30k miles:
317 cylinder heads. SOLD
lq4 intake manifold with fuel rail and injectors. $100
lq4 engine/trans harness SOLD
5.3 block with main caps. $125, might have a crank somewhere.
5.3 rods and pistons. $40
5.7 aluminum ls1 block out of corvette. has hairline crack in rear, wasn't leaking oil when running. $150
5.7 ls1 rods and pistons with new rings and rod bearings. $200
2 stock torque converters for 4L60E, 1 out my truck with 35k miles, other out of a camaro with 50k miles. $40 each.
factory y-pipe that came out of my 03 silverado with 25k miles on it. SOLD
stock shocks off my 03 silverado. $40
ls1 efans. SOLD
Blackbear efan harness with dual pcm pins. SOLD
overdrive alternator pulley. $25
added parts:
03 PCM for my truck. efilive SD tuned for 75 shot, tr220, bolt-ons... $90
5.3 flexplate $40
stock front speakers out of my RCSB $20
Last edited by bluecajun5.3; Apr 8, 2011 at 11:26 AM. Reason: lowered prices and sold parts in red.
Old Feb 14, 2011 | 01:10 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Will the fan harness work on a 2002? If so PM me a price on the efans and and Black Bear harness shipped to 73521...
Do the fans come with mounting hardware?
Old Feb 14, 2011 | 01:12 AM
1SlowHoe's Avatar
Also PM Blown06 about that wiring harness....
Old Feb 14, 2011 | 11:13 AM
website for the harness says... Dual Pin (OEM Operation; 2003 & newer trucks/SUVs, excluding Trailblazer SS)
no mounting h/w for the fans. i used zip ties which held up for the last 5 years.
Old Feb 14, 2011 | 11:20 AM
1SlowHoe's Avatar
Let me look into it today. I know my tune has the fan option. The 2002 flex fuel trucks had a lot of stuff that was standard on 2003. I will try to call black bear tuning today...
Old Feb 14, 2011 | 03:57 PM
s10xtremist's Avatar
Pm'ed you...
Old Feb 14, 2011 | 05:12 PM
1SlowHoe's Avatar
Well I want the fans for sure. Can you get me a shipped price to 73521?
If I hear back from Justin before you ship, I might take the harness (if it will work for me).
Old Feb 14, 2011 | 10:51 PM
Bump for a good seller...
Seth
Old Feb 14, 2011 | 11:00 PM
1989k1500's Avatar
The only difference should be that instead of the second wire going to the pcm he has to tap into the green a/c wire.
The 99-02 trucks cant run the fans off just pcm pins, needs one pin to 42(?) on the pcm and the other wire to the green a/c wire or a switch.
Old Feb 14, 2011 | 11:56 PM
1SlowHoe's Avatar
Sorry to ***** up your thread...But if this is what my PCM can support (series parallel fans), shouldn't that harness work?
