06 2500 6.0 Misfire issue
Hey guys im currently trying to figure out what is causing the misfire issue on a 2006 2500HD. Ive done a lot of things to try and figure it out but still have not been able to locate the problem. Trust me ive been searching lol
The truck started with a P0300, as I watch the misfire counter, cyl 1 is the only consistantly missing cylinder. I will sometimes pick up a few misses on other cylinders but nothing hard enough to pursue. So ive tried to isolate the problem with what ive done so far...
Swapped coil packs, wires, and injectors with cyl 3 (one at a time of course) new AC plug, injector drop test, spark output is the same as it is on cyl 3, checked extensively for an intake leak with brake clean and a smoke machine,exhaust is not restricted, Cam signal looks good, Ive had both cam and crank sensors out and they are fine, Ive done multiple crank relearns with out any change, Compression test 155 on cyl 1, had the valve cover off no broke valve spring, rocker arm action while cranking looks normal... the only thing i havent done is a leak down test but i dont think this will yeild me any different results... but im gonna probably end up doing one tomorrow
Still just a misfire on cyl 1 at and idle, when you bring it off idle, the truck will smooth out, but when hauling a load such as a boat, the misfire is pretty clear
Any other ideas? Im thinking internal engine failure.... lifter or cam...
We decided that it was probably a cam/lifter failure, GM even has a TSB on that year 6.0
I am having the same issue on my 06 Tahoe 5.3l. Is the same, number 1 cylinder and mine also shows a p0172 code. I thought I was missing something and the garage I use cannot find anything also. Let me know if you find out what the cause is.
