3/4 ton, 6.0, 80e, 3.73 - towing with cam ?
LS1 Tech Veteran
Certainly the HD has no problem towing 4000lbs. It should toy with that. But I get the feeling you dont like the sloppy pedal/want more low end. Steve Bryant even runs as small as a 200/208 cam I believe and says his 6.0 tows like a charm. The duration might seem small (even up to the 212/218) but I think the key thing is the added valve lift, it just allows a lot more air into the cylinders.
Steve
therock
07-25-2015 09:23 AM
Suburban2500
07-19-2015 04:50 PM
