4L80 to 6L90 swap
I just want more gears... the 8100 only spinn to 4800 rpms.. and 34" tires and 4 gears to choose from it would tow a LOT better with more transmission gears... both our denalies have the 6L and its awsome in a stock suv... lol.. nothing like dropping 3 gears at 80 mph when you want to pass some one
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
The 6LxxE series is really nice with the deep first gear and the taller overdrive than even the 4L60E. Of course, installing one in a pre-07 vehicle can be expensive and a headache. You will have to use both PCM's to control the engine/transmission and the other to run the gauges.
Good luck.
Good luck.
Good luck.
Good luck.
Which tranny did u go with, didn't you use the 6L80E?
i was interested in this as well but i think im just going to go with the gear vendors overdrive... can split it to an 8 speed or just use the overdrive on 4th and make a 5 speed, either way its only 3000, and bolts in. a bit easier that a 6l90 conversion.
note: the tci was a 4l80, converted to 6 sp, used paddle shifters though...pretty b@d @$$ IMO...
$600 - to have Speartech modify my wiring harness to plug into my truck, run the gauges and operate the A/C.
$200 - purchase of a longer rear driveshaft to fit the shorter 6L80E transmission.
$100 - installation of new U-joints on front drive shaft and have it cut 1" shorter.
$80ish - for two 07+ A/C hoses to accomodate the newer compressor connections. This wasn't needed but I chose to use the new compressor instead of the original one on the engine I took out.
That was it to get it going.
Of course there was the cost of the engine and transmission that I purchased as a package so i can't break the transmission cost down.
I used the 6L80E version.
Hello you all,
I have a 2005 GMC Sierra 2500HD SLT Crewcab shortbed 4X2 with the 6.0 Liter and 4L80 transmission and 4.1 gears. I would love to swap in a 6L90 transmission, what parts would I need to make everything work like it should?
Any help would be greatly appreciated!
PS. I had a 2003 model just like this with the 6.6 diesel and 3.73 gears, however, I prefer the gas engine (I do no towing whatsoever)...![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
Speartech did a Gen IV LS2 6l80 swap in a GMT800. https://www.performancetrucks.net/fo...d.php?t=401899
No one makes a standalone kit. I called TCI and they said no. And their 6 speed is just a modded 4l80 and is WAY over priced.
The only way to do this is swap out the crank trigger to the 58x one = $$$$. Or swap to a Gen IV motor LY6 or L92. As the TCM in the 6l80/90 needs to talk to a Gen IV ECM for it to work right.
as it was said, nobody makes a stand alone kit for the gen IV gm transmissions.
