6.0 slug
#21
ah i was close..
i tuned a buddys RCLB 4x4 2500, it woke it up a ton in 4L
Does dirt drags and its just fun, it use to barely even mess the dirt up, now it spins thru the top of 2nd.
#22
Yeah. Mine is still a turd out of the hole with all the weight on it.... but a lot less of a turd than stock. 3.73's make 60 mph rolls fun though. Backshifts into second and then hits third just under 100 mph.
#23
I found my 02' 2500HD was quite useless and barely downshifted on acceleration. Causing the engine to lug and it fought for every bit it could. I then started to watch the RPM gauge and it would barely every reach over 3000RPM even when I put the pedal down.
I started shifting it manually and revving it over 3000RPM made for a much more satisfying driving experience. I think an HD2 shift kit and an ECU tune would wake it up. A completely built 4L80 with a manual valve body and ratchet shifter would be even better, but not practical for my current DD/work truck LOL
#24
Tuning is all you need. I can backshift into 1st putting my into at 70 km/hr now... Way better than stock. My shifts are firm, positive and where I want them. I really don't see a need for an HD2 on my truck. I would put my HD2 in an 80E behind a turbo'd 6 liter..... But a stockish LQ4 in a 3/4 ton..... it's a waste of money imo better spent elsewhere. If you need a new trans, sure toss it in during the build. But it's not like you will gain anything significant from it's installation. I use this thing for work so if it would gain me life or longevity I would install it. I'm not worried about it.
GMCtrk
18
10-06-2015 03:48 PM
Cammed4ever
09-30-2015 03:38 PM
