6.0 turbo 400 swap
6.0 turbo 400 swap
I recently bought a 2001 silverado I am going to build a mud truck out of it. I an wanting to put a 400 turbo in it the 4l80e is dead. Does anybody know what all I will have to change to make this work. Will I have to have the computer flashed.
Rebuild or aquire a used 4L80. You will want the OD to help you get home so you can gear it deeper if you want.
You can make a 400 work, but hooking up a ported vac would be hard and a kick down cable would be too. That or you have to run the truck with a manual valve body to make it work. Either way the 4L80 would be cheaper.
SPAM HUNTER
From reading around the site, flexplate, converter, trans, lines,and driveshaft, not sure about crossmember setup, and you would have to have a custom trans tune made im pretty sure.
But 80e is strong, but way more expensive.
Dustin
Dustin
I can understand why going with the TH400 over the 4L80E but for this application it might be in your best interest to go to a reputable trans shop and tell them your plans and have a trans custom built
The truck is a 2 wheel drive that I am going to make a 4 wheel drive out of it. I am going to run 2.5 ton front and rearends sodrive shafts will have to be made anyway.I just dont thank the 4l80e will hold and its cheaper to have the 400 built when it breaks.
LOL we use internals from a 4l80e in 400s to make them stronger. Basically an 80e is a 400 with overdrive. 75% of the parts are interchangeable.
GrooveCityZ71
08-31-2015 12:05 PM
