6.5 turbo swap info needed on PCM ect ????
Old 03-12-2013, 05:56 PM
  #21
SCREAMINXL's Avatar
BBC is killing it on gas. Engine in question is a fresh 6.5 with the lower comp pistons, re spec'd turbo. Not looking to dump money into it, esp the cost of a cummings, then trans ect. Going to trade a friend even up BBC, trans for the 6.5 trans/pcm.. They run well enough. It's not for racing or pulling just better fuel mileage..
Should work well for you if thats what you want. Keep us posted on the swap.
Old 03-12-2013, 08:31 PM
  #22
Registered User
tman_2006's Avatar
I think you picked the perfect set up for the purpose. Check in with some updates.
Old 03-12-2013, 10:54 PM
  #23
Baltimore Whore
Mangled03gmc's Avatar
I will, prob not going to do anything till the weather starts to get nice. To be honest I believe that the 6.5 will walk a circle around the big block that is in it, esp considering it will have OD, be able to run up the beltway at 60mph and not be tacking 3k.
Yeh it was a freak of luck that this dude happened to have this set up. Still waiting to get some specs as to the actual components, but I do feel it will suit this truck well. I wish the cummins could be had for cheaper, but o-well.
Old 03-13-2013, 08:08 AM
  #24
Registered User
tman_2006's Avatar
Cummins is loud and shakes, no the best for a cruiser. If you dont mind a HP limit and not being able to run 60 psi boost or roll coal everywhere then the 6.5 will do great and it will surprise you with a load.
ZONES89RS
21
09-24-2015 05:58 PM
Bluecollar Hotrods
07-16-2015 08:52 PM
Aboss
07-09-2015 10:28 AM
Sbrown06
07-09-2015 09:21 AM
Quick Reply: 6.5 turbo swap info needed on PCM ect ????
