8.1L StainlessWorks Headers are ordered!!!
Old 02-05-2009 | 07:32 PM
  #41
Slowhawk's Avatar
LS1Tech Sponsor
We've installed a few of them.They go in easy but all of them needed clearancing at the steering shaft. I would personally buy a stainless Diesal 4" cat back,Flowmaster 3" to 4" Y merge and piece it in there.
Old 02-05-2009 | 08:39 PM
  #42
Whippled 496's Avatar
Thanks again HOG.....Thats kinda where I am now.......trying to decide on the 3's or a single 4". Good exlplination on the X-pipe...that does make sense.
I have also heard the same thing Slowhawk....can you "define" clearancing? Did you have to heat them up, ding them, bend them, move the shaft over a little? How did you make it work and how close was it to the shaft before and after the clearancing? Did they ALL need to be clearanced. I have heard that some do and some dont....maybe its year specific? Do you have any pics? Starting to sound like it may be easier "and" a little less expensive to go with a single 4" setup. The question now is...(as i am kinda stuck on the magnaflows)...do they make a 4" in/out magnaflow muffler?....I have to go an check.
Old 02-05-2009 | 08:53 PM
  #43
I found 4" magnaflows but they are under the "racing muffler" catagory....wonder how much difference there is in sound between them and the standard muffler. They only come in 14" body/20" total length designs.
Old 02-05-2009 | 09:14 PM
  #44
Mangled03gmc's Avatar
Baltimore Whore
You said you want it loud.. Go check out dynomax bullets.. They sound awsome.. I am up in the air on running the race magnaflow or the dynomax bullet.. Also here is a short mag http://www.magnaflow.com/02product/s...e=main&id=7639
Old 02-05-2009 | 10:09 PM
  #45
LOL...no...not loud. I want mild idle and cruise......then a nice sound when I stomp on it. This is still going to be my camping and cruising truck as well as my 1/4 mile truck. I want to keep it somewhat tolerable.
I have found posts that say the racing series mufflers are loud, so i am not going to consider those. Can I use a diesel muffler on a gas engine? I see magnaflow makes some nice 4" and 5" mufflers (non race series) but they are labeled "diesel" mufflers and they are also labeled "resonators". I will have to call Magnaflow tomorrow and talk to someone.
Old 02-06-2009 | 05:41 PM
  #46
Slowhawk's Avatar
LS1Tech Sponsor
I think it's #4 tube.All I did was heat it and hit it.Wasn't much.
We ran a Stainless 4" Diesel exhaust from Summit Racing.It was maybe $400 for the whole setup and the muffler they supplied was perfect.
Old 02-06-2009 | 07:22 PM
  #47
skyhighsami's Avatar
no title here
Magnaflow makes a dual 3 inch inlet single 4 inch outlet muffler. Then get a 4 inch tail section from their diesel systems
Old 02-06-2009 | 08:50 PM
  #48
BigCountryx's Avatar
So does Aero, STX640
Old 02-06-2009 | 11:08 PM
  #49
Stopped into the exhaust shop today and threw it up on the lift. After an hour or so of looking threw part #'s and looking at the layout underneath the truck we decided on 3" true duals all the way back. We will go into an X-pipe muffler (part number 12599) and run the ultra high flow CATs. Given the unequal length of the headers he said it would be a much cleaner install to go with the X-pipe muffler rather than an X-pipe and seperate single mufflers. The whole job including the stainless pipe, muffler, and CATs is going to run me about $1100. That will include a nice set of 4" tips on the end. If the headers come in this week, i will install them the following weekend and be ready for the exhaust shop by the week of the 16th. Fingers crossed.
Old 02-09-2009 | 07:45 PM
  #50
Slowhawk,
Did you come up from the botom on both headers for the install? Anything special I need to know?
Also,
I picked up 2 Magnaflow 59920 CATs. Ultra high flow, 3.5" in/out that I will use reducers on to mate up with the 3" pipes. Should allow more than enough flow. HEaders should be in this week and I hope to get them on by this weekend if they do come in.
Quick Reply: 8.1L StainlessWorks Headers are ordered!!!
