Any tips/suggestions for new diesel owner?
a "chip" is what they used to call them and a generic term for a tune/tuner. You can get a handheld like bully dog, edge, etc, but EFI live with the DSP5 switch is the way to go. Some of the guys out where who do tunes are amazing and will make it a completely different truck, even if your switching from a tuner to EFI live
Got the truck today and found out quick that they bent the drive shaft lifting it with a fork lift at the yard. Now I get to chase down a part and spend more money on something that was not broken.
11 sec. Truck Mod
That's enough . Your not going to be a smart *** in my section, help out or stfu .
Sammy, welcome to the diesel world , you will be very happy with your truck , they have awesome power , excellent towing capability and great mpg, they do everything well.
First of all lets ID your truck, it bieng an 05' has the LLY DURAMAX engine with the 5 speed Allison ( it's auto right?) if not it will have. ZF 6 speed manual.
Here's my recommendations,
Use rotella 15w40 oil
Change the fuel filter every 10,000 miles
Change the Allison spin on filter every 10,000
Change the t case fluid once a year with fresh dex 6 trans fluid
Performance wise, get an EGR blocker plate
Install a turbo back exhaust
Get a cold air intake or mod the stock box
If you want a handheld tuner get a PPE Xcelerator, or for custom efi live tuning get from Idaho rob ( adrenaline truck performance)
Don't go over a 100 horse tune on a stock trans.
Also drain the trans fluid and replace with synthetic transynd.
Get EGT and boost gauges installed
Get a good lift pump
Enjoy one hell of fast heavy truck that will move mountains !
Custm2500's Rude Friend
They were used from the mid to late 80's up until the mid 90's in various cars and trucks.
As mentioned on a diesel the best thing you can do is get a custom tune that is done in person to tailor it to your driving habits and needs.
The DSP5 switch would be the best option as you can go from basically stock and turn it up as needed by the **** and then back to stock if you would like.
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
I am having a problem now as the truck was sitting at an auction yard. It started when they first got it but now the outside lights turn on and odometer displays the miles when we have jumper cables on it. The dash lights do not turn on and it does not start. I checked all fuses and nothing is blown. I posted this in another friend and I am desperate to get this going because it is my only daily driver now and with it out of commission I have to get rides everywhere. Thanks again for all your help and to add it came with a full exhaust system but I am not sure what kind.
11 sec. Truck Mod
Yes it is a 2005 Silverado 2500HD 4x4 with automatic trans and 6.6 liter turbo diesel engine. I am going to do my first oil change and will get the rotella 15w40. I am assuming I can pick that up at autozone? Special oil for diesel or is it all the same?
Thanks I will get to wal-mart to buy it if thats what you mean by wally world lol. Well I have two dead batteries and I am hoping thats the problem.
