duramax fuel issue
#32
idk what it is, but its the little plug thing that screws in to the larger hex thing at the bottom of the filter, once it started leaking i took it out and put it back in twice and its still doing the same thing...?
#33
What most likely happened is that the drain plug cracked when putting the filter in, I have done it a couple times myself, I would go to napa and get a new water in fuel sensor and put it in
#34
I messed with it some this afternoon and it looked like it was just leaking past the seal on the plug and just coming out the hole in the middle. So I just plugged that hole and will see if that works when I get back home in a few hours
#35
It seems like plugging that hole has at least helped the problem... It fired up after just a few seconds this morning, so at least it seems like its holding its prime now
