Duramax swap?
Old 10-11-2007, 04:45 PM
turbonewf's Avatar
Default Duramax swap?
Does anyone know if the new Duramax drivetrain fit in the 73-87 body style? I have an '85 C1500 that I'm restifying, and dont want to go the Big block gas engine route. I am boxing the frame and using 1 ton suspension parts (dually) what should I be aware of?
Old 10-11-2007, 08:36 PM
11 sec. Truck Mod
TIM Z's Avatar
im sure it will, ive seen an 87-98 body style stepside with a DMAX as well as a 87 Grand national and a 63 impala, GO FOR IT!!
Old 10-11-2007, 09:02 PM
Piss Pumps for Sale
Chevy Cowboy's Avatar
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
It should fit in the pre 87 body style, seen one a few months back with a d-max, dont remember the site but a guy did it. Alot of fabrication time and money was involved from what I could tell
Old 10-11-2007, 09:03 PM
speedy02's Avatar
You would probably have to go with a 4L85 transmission. I don't thank you will get the allison to fit with out doing some cutting.
Old 10-11-2007, 09:04 PM
Piss Pumps for Sale
unless he does a body lift? that might be an option, then again the amount of fabricating he will be doing anyway, he might as well just do a custom transmission tunnel?
Old 10-13-2007, 08:06 PM
turbonewf's Avatar
Trans tunnel mods are not a problem, I have to replace some sheet metal anyway. A body lift is definately out of the question, I am going for a minor drop. maybe a 2/3". Fabrication is not a problem. I've built a few race cars in the past. and the truck originally had the 6.2 diesel
Old 10-16-2007, 08:16 PM
turbonewf's Avatar
Maybe I'll just go with th cummins
Old 10-16-2007, 10:29 PM
Wide Open's Avatar
There was a write-up on a 73-87 pickup that a guy swapped in a Cummins recently. I believe it was in last months Diesel Power mag.
Old 11-26-2007, 02:11 AM
nekkidhillbilly's Avatar
cummins is an easy swap on them pretty much bolt in
but there was a guy who had a lb7 6 speed swap on a mid 80s crew on the diesel place
will require some cutting on the tunnel not to much and maybeye few little fab mods
Old 11-27-2007, 07:50 PM
ThrottleHappy7's Avatar
I'm going to follow this one. I've thought about doing this because I, too, don't want to go the usual big block or modified small block route. Does anyone know of links to some swaps?
Quick Reply: Duramax swap?
