Duramax Swaps
Old 08-30-2011, 07:42 PM
  #31
zeake's Avatar
Originally Posted by chpspecial
Here is another idea... this tuck uses a cadillac eldorado 500ci transverse engine to make it FWD, so that rear wheels can tuck in like so...
Cabover First Load-show0.flv - YouTube
That was bad to the bone.
Old 08-30-2011, 08:14 PM
  #32
Need More N2O Mod
mwalls54's Avatar
I picked up a 62 1 ton dually for free so i can do this exact project. Might take me a few years but one day.
Old 08-31-2011, 11:10 AM
  #33
Custm2500's Rude Friend
1FastBrick's Avatar
WoW thats crazy!!! I would like to see the mechanical side of how they made that function.
Old 08-31-2011, 11:12 AM
  #34
SLCviaAK's Avatar
Originally Posted by JankesGTO
Im stil trying to figure out how I could get a RCSB LBZ 2500 nnbs
There is a dude over on duramaxdiesels named Lennart. He is over in germany. He converted a RCLB to a RCSB using factory parts. He created a PDF "how to" for any one to use. I believe he named his build thread "the short cut" or something like that. His truck was an 04-05 ish. But the frames from 01-10 are pretty much identical.
Old 08-31-2011, 11:32 AM
  #35
charcoal03silvy's Avatar
Buddy of mine has a 6.0 Powerstroke RCSB f250. chopped frame and bed and lowered
Old 08-31-2011, 02:26 PM
  #36
chpspecial's Avatar
Easy really, because the truck is FWD, there is nothing that isn't moveable. He used two slide axles and a line lock IIRC, you can hear the pneumatic solenoids engaging and disengaging the lock pins. So, he just unlocks the pins, engages the line lock, and then uses the trucks power to slide back and forth. His goal was a very low approach angle so that he could get any of his cars on with no fuss.
Old 08-31-2011, 05:48 PM
  #37
SLCviaAK's Avatar
Short bed conversion - Duramax Diesels Forum
This is the thread that has the PDF with the "how to" for the 2500HD long bed to short bed conversion.
If any of you guys did, or are doing this type of conversion- speak up. Show it off!
One of my (many) dream trucks is a NNBS LMM 4wd RCSB, lowered 3/5, 22's, built trans, built long block, big injectors, dual fuelers, custom tuning for no (or little) smoke, and a set of Extreme Predjudice Racing Triple Turbos. Should put down 900+ hp/ 1300+tq easily. And probably pretty good mileage too.
If only i had metric **** tons o money.......
Old 09-23-2011, 08:53 PM
  #38
Leroy_454's Avatar
C10_v1
PPE's C10 dmax swap
Bluecollar Hotrods
06-11-2024 11:37 PM
Rafe19
10-18-2016 12:27 AM
GREENMILE
09-03-2015 01:29 AM
GREENMILE
08-03-2015 05:55 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: Duramax Swaps
