EFILive announces DSP5, 5 Position Tune!!
DSP5 - The 5 position switchable tune
Well folks, you have been asking for it and here it is.
EFILive is proud to announce that our new 5 position switchable on the fly tune is well into Beta testing stage and will be released shortly after SEMA along side the TNT program. If you are coming to SEMA be sure to drop by our booth (#13059) to take a look first hand at DSP5 and the new V2 hardware.
With EFILive being the first to offer all Duramax DIY and professional tuners the ability to create their own switchable tune we've stepped up to our customers requests and created DSP5. This is for both LB7 and LLY.
So how does it work and what are the features?
Simply wire in the switch (which some of our resellers may stock), create your new tunes to switch between in the EFILive software and away you go.
Stock, then Tunes 1 - 4.
But you know we wouldn't stop at just a 'simple' 5 position tune, we've also added another feature called DSP Staging.
DSP Staging allows you to define some thresholds by which the ECM will limit fueling (see pics below). So as an example, you can set it up so at 1800RPM you start to limit fuel to get consistent drag race launches, set the DSP Launch control to bypass the limit above 50% throttle so as soon as you mash the pedal full fueling will occur for the run down the strip.
We also have our controllable output and valet mode, all in all, what more could you want?
http://efidownload.iqd.co.nz/softwar.../DSP5_Pic1.png
http://efidownload.iqd.co.nz/softwar.../DSP5_Pic3.png
http://efidownload.iqd.co.nz/softwar.../DSP5_Pic4.png
http://efidownload.iqd.co.nz/softwar.../DSP5_Pic2.png
Originally Posted by TIM Z
Available yet?
LBZ tuning is already available in public beta, But I believe it will be Officially released next week as well.
If you have any questions let me know
11 sec. Truck Mod
Originally Posted by kbracing96
Almost, should be early next week I think is what I heard, but The DSP5 - 5 position switchable tuning won't work for the LBZ
HIDEXTRA
07-21-2015 05:43 PM
Mossyoakglock
07-17-2015 08:30 AM
