EGT cause limp mode?
I haven't really noticed any tranny slip.... but I have noticed that my EGT's run around 1000* with average driving and run up to around 1250-1300@ WOT... I have heard that it shouldn't go over 1000* before... which that was with a stock tune... I am running a 50hp tune through a power pup
I've noticed that BullyDog chips usually have a problem with not calibrating for higher boost numbers that their products create. Im wondering if its a high boost problem?
Any codes?
Any codes?
limp mode= the pcm not allowing the engine to go past 2000rpm to keep from burning something up.... i've heards its more common for tranny problems...... but I wouldn't think a 50hp time, a CAI, and an exhaust would be making enough power to even hurt the tranny... and I damn sure haven't put any big loads behind the truck... just a car hauler and a 4 wheeler trailer
I haven't checked for any codes but the SES light isn't on.... I gotta find my damned programmer so I can check it. the boost never goes past about 20 psi and hardly ever sees that(unless its @ WOT... which isnt that often)
I'm not sure what the damned deal is.
Originally Posted by The Guy in MY 99TA
i'll do that.... uhh dude when did you do add this here camaro to the stable? When do I get to see this thing run?
ahh you pansy ***.......... you better get on tha ball if you plan on outrunning my red car!!!! My projected run date is well..... just whenever I get my lazy *** down to the shop and pull the old k-member and **** out and put the new **** it and then I gots to finish the final engine assembly and drop it in... the tranny and converter is supposed to be here today
MA$TER_E
09-09-2015 03:14 PM
