Factory duals Y'ed into a single 3"
Im pretty much committed to the 3" setup now......just ordered LTs, ORY, some DEI heat wrap, and a Walker 36" Big Truck Muffler from Summit. Im going for an even quieter set up then the 22" Magnaflow that everyone is running.
Now I just need to see how to snake the piping in and around the crossmember after the 3" ORY terminates.
2500hd 6.0 exhaust.........help!!!
any ideas for the exhaust on my 2500hd with the 6.0? its oe now with the muffler cut off im just trying to figure out a good set up that wont restrict any power and sounds good.
I have the same truck and I went with:
-Pacesetter LT's (70-2265) and ORY
-Dynomax 3" flanged Intermediate pipe (53104)
-Walker 36" Big Truck Muffler
-4 Walker 3" lap joint band clamps
-new OE exh manifold gaskets
-And I found and 3" tail pipe section with a nice angle-cut tip at a local wrecking yard for $30.00
Got it all form Summit (except for the tail pipe section) and Im only in it $594 + 11.95 S&H
I just ordered the DynoMax cat-back system kit #19458 from Summit for $309.95. - specific for the 06 1500HD 6.0L. YouTube has plenty of videos to compare and I found the DynoMax Super Turbo a good starting point for my taste. Next was the Banks Monster single outlet; Magnaflow & Flowmaster wasn't doing it for me.
DynoMax has a $75.00 rebate going 'til 8/31, too. Can't beat that net price. This is the first mod purchased but won't get installed until I can get to the dyno for the full stock baseline on this LQ9.
My local Tires Plus had Bridgestone Revo's (first gen) in 285-70/17 for $169.99 so I jumped at those too (33" vs. 32" for the 265-70/17). Speedo recal pending.
I absolutely hate drone too. I think the trick is to not dump it right after the muffler. Make sure you run whatever you get out the back.
For the longest time I thought my all my drone was coming from my current exhaust (dumped Magnaflow), but it was my aftermarket CAI. The other week I put my factory airbox and resonator tube back on and 90% of that nasty howl is gone under hard acceleration is gone.
I'll try and do a sound clip and a bunch of pictures when I finally get around to it.
thanks id really appreciate it, and yea i have a cai and throttle body spacer along with a ported and gasket matched throttle body so that makes alot of noise but im leaving all that i can deal with a little drone and raspyness lol
