Fastest 8.1 Thread...
I built a 2006 2500 hd 4x4 8.1 using raylar Heads, Intake , Diamond pistons , Manley Rods , SW long tubes , Custom 4 inch Rear mount turbo BW S480 on 10 psi , fuel system , Meth , ATS Ally , 4:10's ... Dynos 800hp 800tq to the wheels on our mustang dyno ... Went to the track using ats five disc stall for a duramax 500rpm tighter then stock [I guess they didn't here me that i was building a GAS 8.1 ] ... The truck wouldn't make boost till the 330 mark ... Still went mid 12's @ 117-119 mph ... Now with new Vig stall 2800 5 disc with turbo stator [ Leaves at 3-5 psi on foot brake ] I would guess mid 11's ... Track is still closed ... Oh FYI 60ft 2.5 LOL
Went 13.6 @104 last year and 13.80 @103 this year at LS1 shootout. 4x2 3:73 gears 13psi boost on twins pump gas and 7k lbs. 60' 2.3. Will prob add Caltracs when I can, like to throw is some 105 Octane and up the boost but worried bout strenght of stock pistons...
he said it was dropping at 5000 88 kpa, intake is a known restriction on these motors. He said once i put my custom intake proper sized injectors and open up the intake before the tb and bigger tb i should defintely see a change. I was 122 percent duty cycle on stock injectors at 67 pounds of fuel pressure
Definitley sounds like there is some induction restriction there. Swap out from the stock 75mm tbody and grab some marine 8.1 42 lbrs or better.
I remember the 525hp HP3 8.1 used the same fuel map as the 420hp HP2 but used a different regulator to up the fuel pressure to support the 525hp. The 420hp HP2 used the 300kpa(43.5-3BAR) FPR and the HP3 use the same injectors but 400kpa(58psi-4BAR).
They used the stock 8.1 marine injectors and port matched intake.
peace
Hog
peace
Hog
