Finally! Modified Stock 8.1L Intake Manifiold Numbers!
Hey all, we finally got the 540 burban tuned on the dyno with the ported / modified stock intake manifold and 80mm throttle body. 22hp/0ft-lbs was picked up at peak, but the power gained throughout the power band more than makes up for the minimal peak gains.
So we're as clear as possible, the "baseline" for the 540 is: K&N intake, stock throttle body, mild porting on stock iron heads, 203 camshaft, roller rockers, iron head spring kit, JBA "shorty" headers, cats, spintech 8000
The intake run has the ported / modified stock intake manifold and 80mm throttle body with all of the above modifications.
Thoughts, comments, demands for video (its coming soon) are appreciated!
We're in the process of redesigning the new manifold. It produces great power on the top end, but low end power was lacking compared to the Cool Gap manifold with its longer runners. We're going to add more runner length and give it another go. On the upshot, the base plate (2 piece design) will make for a great template for hot rod style stack injection like the old HO750 used to have.
Also, keep in mind the extra 50 cubes that the 4.75 stroke kit adds will tend to make this engine a bit more torquey as well as make the 203 cam act a little bit more like the 202 high torque cam because of the extra cylinder volume. Based on how "boringly" stock-like driveable the suburban is, we figure that the BP-206 will be the hot street choice for the 540 kit and the 203/205 cams will serve more for torquey, low to mid-range applications.
We've got an extra set of aluminum cylinder heads at the shop but they probably won't go on the 540 till July or August. We're planning to put a BP205 cam in at the same time. The 205 is the same duration/lobe separation as 203 cam, but .600+ lift to take advantage of the head flow.
