GM 6L and Allison trany
Old 08-23-2010 | 12:19 PM
Big_Bird_WS6's Avatar
Banned
Default GM 6L and Allison trany
Will they work torgether?
first can you bolt them to each other?
second can you get the computer to understand what is going on?
our work truck has a 2007 1 ton with the allison. and re push the deisel to hard. well it has 101,653 miles on it and GM basicly said **** you.
we have a built 6 L in the back of the shop that we can put a turbo on and make it a great pulling motor. just need to make sure this can be done.
thanks in advance.
D
Old 08-23-2010 | 03:34 PM
lethalperformance's Avatar
i have also tought of this but have never seen it done and it would be grate if it does goodluck on the build if it does happen
Old 08-23-2010 | 03:53 PM
I dont think they will bolt up...
Old 08-23-2010 | 04:46 PM
SILVERADO11's Avatar
Originally Posted by 00z71
i dont think they will bolt up...
x2.......
Old 08-23-2010 | 06:59 PM
xchevyx24's Avatar
there has to be a way to make it work considering alot of older duramax's and 8.1's had 4l80e's instead of the allison so in some way they have to interchange.
Old 08-23-2010 | 07:06 PM
ChevyTruck's Avatar
something else
A guy I know, has a buddy that has a either 01-02 Silverado. It has the 6.0 and Allison trans. So there has to be a way to make it work.
Old 08-24-2010 | 02:03 AM
https://www.performancetrucks.net/fo....php?p=4451526
Old 08-25-2010 | 11:03 AM
hog's Avatar
hog
All GM engines use teh same bolt pattern. 8.1,4.8,5.3,6.0,6.2 305,350 and DUramax all uses the same bellhousing patterns and will allow the bellhousing to bolt up to the block. There may be 1 bolt hole extra or missing, but that doesnt matter at all, all the load is taken by the dowels.
teh toughest part would be the electronics.
peace
Hog
Old 08-27-2010 | 11:18 AM
Banned
peace
Hog
this is the hard part. do i use a stand alone for e the engine or the trany. lol.
calsdad
06-15-2023 12:07 AM
Oobray
06-13-2022 04:38 AM
thunder550
10-08-2015 05:53 PM
La Grey 1
09-21-2015 12:07 PM
PSM
02-19-2004 09:04 PM
