How do you remove shmut filter on 2007 and up duramax?
Im considering buying a 2008 duramax diesel and was wondering if its possible to remove the shmut filter to get get better mpg and better air flow and if so how do you do it?
there are several ways to shut off the dpf codes and remove the dpf. Quadzilla Stealth II is the least expensive (about $375-$450 depending on where you buy it) and comes with 4 different power tunes. PPE makes nice stuff (about $599 for the street tunes) and can also shut off the dpf codes. EFI Live is nicer still if you want to do your own tuning or use multiple tunes from different libraries/vendors, but also the most expensive at $749.
Jody
Jody
SlvrSierra4.8
10-01-2015 09:39 PM
