How to tell what rearend I have?
Hey Guys I haven't been on here in awhile and I have a question. I just bought a 2001 Chevy 2500 HD. It has a 6.0 , auto trans , 2wd, regcab. I just wanted to know how do I find out what rearend it has and what the gear ratio is. The rear does whine a bit only when I am on the gas but when I let off the gas it is quiet. So there is something up with the rearend.
I have a 99 sierra that did the same thing so I had it rebuilt and upgraded everything. 2 grand later it is bullet proof.lol Now on this 2001 Chevy I just want to go cheap as possible so I have to weigh the odds of getting a junkyard replacement or to rebuild.
Thanks in advance
Thanks in advance
Ok the only codes in the glove box that start with a "G" is GT5, and GMC.
It does have a 14 bolt rear cover. Also I have been looking at junkyards and they ask if it is full floating or semi floating axles. Brakes are discs in the back if that helps.
Yes it is a HD Truck I was just looking thru some papers I found in the glove box and on the papers from Les Schwab it says that the truck had a brake job last year on the rear. It says that it has semi floating axles. Is there a set in stone way to make sure about the axles semi or full floating? Thanks for the help
03chevytruck
08-25-2015 09:08 PM
BlackDog
27
06-04-2004 09:57 AM
