idle surge?
idle surge?
So i clicked over 133K miles this week and now i have random idle surge. truck internally is stock... has a headers, intake, exhaust... which have been on for a few years..
The rpm will be a 800 then drop down to 400-500 for a few seconds then jump to 1000.. the air fuel gauge goes from 15.4 to 16.8 then shoot to 13.2 ish... then back to 15.8 or so.. and idel is back to normal 800... then a minute or so later it does it again.. But no always.. some days its fine runs all day with out doing it..
So would that be like a dirty fuel filter or what?
Yeah in your case, that might not be the problem. But it doesn't hurt to check anyway. Oh and yeah, clean all around the blade and body. I've seen the smallest amount of build up do alot!
Clean throttlebody.
Mangled,if your afr goes rich when the idle falls,you may need some injector data adjusted,just a thought.Going rich can also cause the surge or make it worse but not always
