Innovators west 8 rib setup on an 8.1L
I bought a set of pulley's from a member that i plan to install on my truck. I am fairly certain everything is the same for the 8.1L as far as pulley's go. I have seen a lot of discusion about the crank bolt and what will and will not work. What do i need to buy as far as a crank bolt is concerned so I can get it put on correctly? And any other helpful tips or advise you may have.
The Keyway in the Dampner is in case you have a keyway cut in your crank. Otherwise you'd have to pin it. The Innovator's West piece takes a special bolt, and spacer. You'll probably have to get it directly from them.
you have to use a pinning kit specific to the IW crank pulley because it is so thick. the drill bit is way longer and the drill guide is different. i can post a pic of it tomorrow if you would like.
Jed
Jed
Nevermind, I found the kit on IW's site and ordered it up. I just hope that the pulleys will fit the 8.1L accessories and crank...LOL. I figure the PS pulley, alt pulley, idler, and tensioner should be fine....I am sweating the crank pulley though, even though it looks very similar to the small block stuff.
81l, crank, gmc, inavator, innovator, innovators, instructions, keyway, kit, pin, pinning, ps, pulleys, supercharger, west
