Propane or Water injection
I am looking to give my truck a little more power and help since I tow almost all the time. I am leaning more towards a Propane injection just because it is a lot simpler to install and what not. However the Water is easier to maintain.
I am just looking for some input and if any one else is running or knows more about them?
hey i have heard good things about both. but i know propane has been around a lot longer so thats the way i would go. both are better than nitrous for your engine to.
Yea im thinking propane it gives more power then the water injection. I remember my dad having a propane run truck. the big benifit that water does it sounds like it lowers the EGT's more then propane. I would also be worried about the water freezing yea i know it is mixed with alcohol but they tend to stay separate so i wouldn't want my lines freezing.
Actually, water and alcohol attract STRONGLY. In fact they chemically bond. They won't separate. I run -20* windshield washer fluid in my meth injection setup on my truck. It is about 30% meth and cheap.
Check out the Devils Own water/alcohol injection. Easy to install.
Well you learn something new each day. Thanks for clarifying that for me. That then makes me more curious into that area. What temps hae you guys had because I know I can get down to -40 in the winter so i want to make sure of that as my truck is almost never any place warm.
Sorry it has taken me so long to get back on here October was a very busy month. My truck is an '05. It is sitting at stock as far as the motor and stuff like that go.
