Valve cover clearance on 8.1 with Comp 1.72 Roller tips?
Old 09-16-2010 | 04:07 PM
BetMinesFaster's Avatar
Down and out
Default Valve cover clearance on 8.1 with Comp 1.72 Roller tips?
Hey guys,
Doing the XR720HR cam swap, wondering if I can expect any valve cover clearance problems with the Comp 1.72 Ratio Roller tip rockers? Cam swap went well with excelent power gains, swapping to a stronger rocker for peace of mind with the heavy pressures on the beehive springs. Track numbers after retune on October 2nd, expecting 14.teens or so.
Thanks for the space and any info on rocker clearance would be great!
-Ryan
Old 09-16-2010 | 06:16 PM
fastnblu's Avatar
While I don't have an 8.1, on my 5.3 I was told to run my 1.75 Comp rockers, I'd have to knock down the casting bumps on backside of valve covers. I'd than have to remove the oil splashback baffles, which supposely some have had issues w/. oil in PCV by doing that. Which may necessitate a catch can, but IDK. I don't really want to do that, nor do I want potential PCV contamination. This guy said he didn't have that problem at all.
Also, another option for me would be to add a spacer, since the rails are so tall on LS motors, leaks wouldn't be a problem. Then, u need longer bolts too. This method will cost more, so I think I'll do the more labor intensive version. Not sure yet, & I gotta see if those spacers are as much as I remember.
That help?
Old 09-16-2010 | 06:22 PM
Down and out
Tho not 8.1 specific it cant hurt! Im doing a 6.0 turbo now too so I can apply your input on that one!
Old 09-16-2010 | 06:33 PM
fastnblu's Avatar
I can't take all the credit, just passin on what I recently learned. I was up late doin my springs, so I slept after work today. Had I not, I woulda called Comp to ask if there was anything special I need(ed) to know on these rockers.
So, tomorrow I'll call Comp to ask a few questions on my rockers. I almsot thought of not running the Comps cause of the labor to make em work, but I can't return em. The oil splashback is all that concerns me really. I figure i'll clean w. brake clean (which I wish there was a better option on an EFI ride).
I'd hope it would dry fast, which it does, but I don't want any brakeclean residue anywhere I don't need.
Old 09-17-2010 | 02:34 AM
xx_ED_xx's Avatar
well the 8.1 valve covers are the shallowest of the bbc, but the heads have a taller cast in volve cover gasket rail. You could put earlier 502 valve covers on but then you need to make a new coil mounting. there is one cylinder on each head that one rocker is really close to the bolt and usually causes interfernce.
I have an 8.1 in a 1500
Old 09-17-2010 | 06:27 AM
thundert56's Avatar
I have 1.7 roller rockers from raylar on my 8.1 and have no issues with clearance raylar also sells 1.8 roller rockers as well so I don't think you will have any issues.
Old 09-20-2010 | 01:34 PM
Down and out
Thanks for the replies guys, As soon as the correct rocker studs show up ill have it back together!
Old 09-23-2010 | 12:51 PM
Kerr's Avatar
Do you mean the XR270HR cam? ive never seen the 720
Old 09-23-2010 | 12:56 PM
xx_ED_xx's Avatar
720 means the valve stays open all the time
Old 09-23-2010 | 01:14 PM
Down and out
Sorry about the typo! XR270HR!
The_W
10-28-2015 09:00 PM
BlackGMC
08-17-2015 07:07 PM
jroctpb
08-11-2015 03:52 PM
DrX
08-11-2015 07:25 AM
low2001gmc
07-21-2015 02:09 PM
Quick Reply: Valve cover clearance on 8.1 with Comp 1.72 Roller tips?
