What mods to boost TQ and pulling power?
Old 06-22-2009, 04:07 PM
12 Second Club
street demon2k3's Avatar
Default What mods to boost TQ and pulling power?
Picked up an 01 2500 with an LQ4 and Im looking to boost tq and hp if possible. I dont want to scrifice tq cuz its my tow rig so Im wondering what type of mods will help?
Longtubes or shorties? <---- stock manifolds but I can get a set fairly cheap
True duals or y-pipe? <-----The truck has true duals with a 2in/2out flowmaster
Thanks!
Old 06-22-2009, 04:17 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Magnuson Radix supercharger.
Old 06-22-2009, 05:49 PM
Mort's Avatar
Haha....
Only if you want to be able to notice the difference...
Old 06-22-2009, 06:54 PM
MikeGyver's Avatar
Originally Posted by Mort
...Only if you want to be able to notice the difference...
I remember how much power I imagined I was going to get with the first mod I ever did to an engine, installing a performance intake manifold. It turns out that you need a blower to get the increase that is in your imagination. A cam will at least give you half of what you hope for in seat of the pants dyno numbers.
Old 06-22-2009, 09:34 PM
PSM
PSM's Avatar
I pull with my truck and while the radix is great, I'd recommend an front mount turbo. A charger doesn't seem to match towing quite as well as a turbo. Primarily you need to keep rpms up to keep power up, where as a turbo will build power as the motor gets loaded, independent of rpm.
Old 06-23-2009, 12:50 AM
MikeGyver's Avatar
Originally Posted by PSM
...A charger doesn't seem to match towing quite as well as a turbo. Primarily you need to keep rpms up to keep power up,...
Huh? Really? Maybe you need a bigger blower?
Old 06-23-2009, 01:05 AM
PSM
PSM's Avatar
I'm only running 6.5-7lbs so that may be part of it. While pulling it will rarely ever shift outa OD so power wise is fine, but I have 4.10's to keep rpms up. Maybe I should have said a blower needs more throttle input instead of saying rpms.
When the motor gets loaded boost does't climb until you get deeper into the throttle. From what I've seen when sized right, turbos get into boost with a lot less throttle input from the driver. The blower has just as much power, you just need to feed it more, where as the turbo can lug a lot harder.
Old 06-23-2009, 03:29 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
+1 for the Maggie for towing duties. TONS of grunt down low where it counts. I tow with mine.
Old 06-23-2009, 05:31 PM
MikeGyver's Avatar
...Maybe I should have said a blower needs more throttle input instead of saying rpms...
Well OK, then.
Old 06-23-2009, 05:41 PM
PSM
PSM's Avatar
or it could be the fact that I don't have all those cubes you do.
or it could be just my opinion... and you know what they say about opinions
Quick Reply: What mods to boost TQ and pulling power?
