Central & Northern ND, SD, NE, KS, OK, MN, IL, MO, IA, KY, OH, IN, MI, WI
Tulsa area FLT install.
Old 02-09-2007, 08:55 PM
  #51
11 Second Club
Z284thgen's Avatar
Originally Posted by truckmann
Ok sure great. Where the heck do I find 101 at?
i think theres a place in sapulpa you can get it
it a oil dist place i will check with buddys from there and get back to you
Old 02-10-2007, 01:31 PM
  #52
truckmann's Avatar
Well I changed my spark tables to some I copied from a tune in the repository labeled "2004 Performance Tune" for a 5.3l Chevy. They looked to be fairly conservative. I attempted to go out and do some data logging and I got about 20 minutes done around town before I ran into the problem that I posted in another thread about my bad day road damage. Anyway the KR side of the log was looking much better only a few small hits. LTFT's are still way too high, but I don't know if the log is really long enough or if my logging is setup correctly to justify those.
I guess this will get me by safely until I get a chance to do more work on it. Since this looks to be safe spark should I use it to start trying to adjust my VE table and then go back to the spark tables?
File Type: hpl
File Type: hpt
Old 02-10-2007, 04:40 PM
  #53
Okie5.3's Avatar
working on your tune a little. what tires are you running?
Old 02-10-2007, 05:37 PM
  #54
truckmann's Avatar
I have P265/75 R16's.
I found what is causing the clunk noise today. The rear cross member that the torsion bars mount to has a bad bushing on the drivers side that alows the crossmeber to move a bunch. I am 99% sure that is the cause of the clunk and explains why I feel it in the floorboard. I wonder how hard that will be to fix it doesn't look to hard.
Old 02-10-2007, 07:22 PM
  #55
11 Second Club
Z284thgen's Avatar
could have been causing knock if it was real bad clunk
Old 02-10-2007, 09:03 PM
  #56
truckmann's Avatar
I suppose that's possible it is a pretty noticable clunk. It would be nice if I could get it fixed tomorrow, but I don't know if I will be able to get the parts on a Sunday.
bearden86
26
11-15-2015 03:58 PM
lukn4trbl355
10-21-2015 11:19 PM
trxmxzx
09-29-2015 07:42 AM
akcooper9
09-13-2015 04:50 PM
norris_83
09-09-2015 04:14 PM
Quick Reply: Tulsa area FLT install.
